help with exhaust
Old Jan 7, 2009 | 10:20 PM
zacxzx's Avatar
Default help with exhaust
i need help taking off my exhaust bcz the bolts are rusty and idk what to do and i dont want to break them off
Old Jan 7, 2009 | 10:28 PM
BlizZard's Avatar
buy some PB Blaster or WD-40
Old Jan 7, 2009 | 10:33 PM
zacxzx's Avatar
i used wd 40 but not pb blaster
Old Jan 7, 2009 | 10:37 PM
topekatc's Avatar
i've used both...as this happens alot when racing on dirt...pb blaster works much better imo
Old Jan 8, 2009 | 02:51 AM
xroad2oblivionx's Avatar
http://www.sears.com/shc/s/p_10153_1...0P?vName=Tools
<--- Those work really well. You just put it on the bolt and it'll dig into the bolt so you can remove it. I stripped my exhaust bolt because it was rusted so i hammered that on and tried taking it off and it worked really well. You'll have to buy a new bolt but those are cheap. Also, you won't need every bit in that kit so you can go to sears and pick up a smaller pack. I think mine was $12
Old Jan 9, 2009 | 06:58 AM
mystik's Avatar
CinSity Scions
you put on WD-40 and let it sit for about 10-20 minutes. then come back and try again. just be sure to get a good grip or else you might strip the bolts if your wrench or whatever slips...
at least thats what i did...
Old Jan 9, 2009 | 07:16 AM
06tcdude's Avatar
sounds dumb. but start your car and let the exhaust warm up. the metal will expand and the bolts will be easier to get off
Old Jan 9, 2009 | 03:40 PM
topekatc's Avatar
^makes no sense at all...yes the exhaust is metal and when metal heats it expands, however the bolts r metal too so wouldn't they expaned just as much?
Old Jan 11, 2009 | 01:22 AM
i'm sure a local shop would take the 2 bolts off for cheap. But if you end up stripping the bolts that bolt remover kit from sears is a great investment.
Old Jan 11, 2009 | 03:06 AM
silverstreaktc's Avatar
get a flathead screwdrive, and spray wd-40 on both the hanger and the rubber mount
Old Jan 12, 2009 | 10:34 AM
davedavetC's Avatar
actually it might work, but he would be better off focusing the heat on the nuts with a torch...
Old Jan 12, 2009 | 05:22 PM
thendawg's Avatar
if the bolts are in good shape - an impact wrench will do the trick ;) but if youre beyond that and the heads are stripped my recommendation from personal experience - if you have access to the equipment - is to weld a nut thats larger than the bolt head to the head of the bolt =- make a secure weld all the way around - the heat from the weld will help the bolt to release and wrench her out using a 1/2" breaker bar ;) I stand by this method as i used it to remove countless large bolts along with the two i stripped the heads on, on the fly wheel when i was tearing down the motor
Old Jan 13, 2009 | 12:21 AM
BZinn1's Avatar
We always used a torch after WD40 to break up the rust holding it on.WD it and wait 30 minutes then hit it with a torch to heat up the bolts,then wait for it to cool and use a good wrench,make sure it is not a 12 sided wrench,use a 6 sided one and it will come right off.
brett561tc
Sep 15, 2015 06:33 AM
Dutch_tC
Sep 7, 2015 05:13 PM
carid
Feb 9, 2015 01:49 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
