quick update on the car.
Old Jan 11, 2009 | 09:36 PM
Crayola_G's Avatar
Default quick update on the car.
as some of you guys know, iv been having little issues here n there, but its bout that time i get her running right, gona be turning up the boost to 11-12 n getting retuned. I just ordered the 255lph from dezod, gona be installing it as soon as it comes in,
Is it difficult to install myself? or should i get it installed, i mean i installed my own turbo kit, so i cant imagine it being anymore challenging than that. its just that there are no install guides anywhere online or on this forum....
Old Jan 11, 2009 | 11:30 PM
B_Real45's Avatar
Default Re: quick update on the car.
I'm in the same boat.. I have one sitting right here.
I haven't done it yet because I don't have money for a tune now.. and I think if I install it, my car will idle and drive funny cuz it might be too rich.
Old Jan 11, 2009 | 11:41 PM
deathbyc4's Avatar
walbro can be a pita to put in, mainly the cap that clips on the end because the pump is slightly longer than the case in most cases. you may end up extending the gaps of the clips on the cap to clip onto the cylinder around the pump.
Old Jan 11, 2009 | 11:51 PM
m6ar2cel6oTC's Avatar
hey rob in your case it might benefit you if you install the pump since you are running a lil lean. my buddy (one with the black 240)told me that in some cars when you put in the pump it richens it out a lil or doesnt do much depending on the tune. oh and by the way he ran a 11.7 that night (my boy with the black 240)!
Old Jan 11, 2009 | 11:58 PM
B_Real45's Avatar
Niiice! I'm glad he was able to get in better runs.
He must've had his laptop with him this time huh? Enabled the AEM two-step.
Old Jan 12, 2009 | 12:03 AM
yup! he raced my buddy also in the c6. and gave him 2 cars lengths and still beat him lol
Old Jan 12, 2009 | 12:18 AM
cburglb34's Avatar
leave it at 8-9 psi for a bit...u just got the car running fine, dont risk the motor
Old Jan 13, 2009 | 09:13 PM
purevision01's Avatar
The fuel pump can be installed by yourself, but you will need a dremel to make it fit in the stock housing... Be sure the order the low pressure 255 and not the high pressure... The high pressure pump will cause you to run rich but it will still be driveable... The low pressure should go in without much change to the afr.
Old Jan 13, 2009 | 09:20 PM
Crayola_G's Avatar
the fuel pumps so gone that anything will make it run better lol
Old Jan 13, 2009 | 09:35 PM
rhythmnsmoke's Avatar
Music City Scions
Shouldn't you get a FPR before installing it?
Old Jan 13, 2009 | 09:37 PM
B_Real45's Avatar
FPR does nothing on a returnless fuel setup (our Stock setup).
You would need to turn it into a return line setup to utilize an FPR.
Old Jan 13, 2009 | 09:42 PM
Music City Scions
You right, forgot about that.
Old Jan 13, 2009 | 09:44 PM
You both are half right... to make more then 400whp a return line setup is need and if this is done an aftermarket fpr is necessary... Adding a high pressure 255 will bump up the global fp but it can be adjusted with injector duty cycle...
Using the low pressure 255 will add volume without addin pressure there by negating the immediate need for a fpr
Old Jan 13, 2009 | 09:48 PM
Music City Scions
This is an area I need to do some more research in. Trying to see how a fuel pump upgrade is going to do any good, if your still using the stock FPR. I would think to convert to a return style setup and add a FPR, fuel rail to increase volume.
Old Jan 13, 2009 | 09:51 PM
B_Real45's Avatar
I know what you mean, Travis.
I purchased the Walbro as a security blanket. I know it's not going to give me more HP.. but it will probably last longer than stock. My goals are only 300 reliable whp on a stock motor. Very simple.
Old Jan 13, 2009 | 09:58 PM
Music City Scions
I do over that now on stock pump. Just 750cc injectors for right now. I can get the Walbro for pretty cheap, but I haven't decided if I want that or the External ARP one. And one of my crew members makes a fuel rail for the tC.
Old Jan 13, 2009 | 09:59 PM
B_Real45's Avatar
Oh really? Lots has changed since I've seen your setup on SL.
Got a dyno and other details?
Old Jan 13, 2009 | 10:09 PM
Music City Scions
Oh really? Lots has changed since I've seen your setup on ScionLife.
I'm actually selling my current setup. Ptuning is my next setup. check the link in my sig. But yeah, 750cc injectors and 12lbs of boost right now.
Old Jan 13, 2009 | 10:10 PM
B_Real45's Avatar
That's really good for a 16G. Would love to see the power curve and tq curve on that.
Old Jan 13, 2009 | 10:24 PM
Music City Scions
Not a 16G.
