brake fluids
Old Jan 20, 2009 | 07:00 AM
DAILYXB-TYPE-R's Avatar
Default brake fluids
i recently change both front and rear brake pads and slotted/drilled rotors and i want to change the brake fluid. i'm not sure which should i use any opions would be great
TIA
Old Jan 20, 2009 | 08:35 PM
al74dart's Avatar
Here read this link. It has a lot of good information about brake fluids. Tho only thing I don't agree with is he doesn't recommend the Ford brake fluid for the street. Ford's brake fluid was designed for the street. The problem is MOST people ignore changing out their brake fluid. That is a problem no matter what fluid you use. Because brake fluid absorbs moisture from the air it needs to be changed regularly. The moisture will affect your ABS from what I have read although I don't know exactly how. But I can see the moisture getting in around the pistons in your disc brakes and causing surface rust so maybe that's enough reason. I change out my fluid every two years or less and I live in Arizona where there is less moisture to be absorbed.
http://209.85.173.132/search?q=cache...nk&cd=13&gl=us
Al
Old Jan 21, 2009 | 02:15 AM
thanx for the info
gqdabien
Oct 8, 2015 05:36 PM
olyellr
Sep 28, 2015 10:32 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
