The Mysterious Sqweak..Continues....
Old Jan 25, 2009 | 11:55 PM
TeeCizzle's Avatar
Default The Mysterious Sqweak..Continues....
Okay...SO I had a High Pitch Sqweak coming from the Passenger Rear Spring...Becuz every Bump I went over made a High Pitch Noise...
To fix it I took apart the Rear Suspension and wrapped the last coil w/ a rubber Tire Tube from a Bicycle. That fixed that Sqweak Noise!
Now a NEW Sqweak developed!...It only happens when I get In & Out of the car!!...
Adjusted E-Brake too!
I tried to Re-Grease the Rear Sway Bar bushing too...That did not work!
Where is this sound coming from??????
I will appreciate if someone could shed some light on this Noise issue!!!..Its Annoying!!
Thanks again in Advance!
Old Jan 26, 2009 | 05:54 AM
mystik's Avatar
CinSity Scions
driver side springs? or, cuz its only when you get in and out of the car...maybe its your seat...
Old Jan 27, 2009 | 02:09 PM
howiedds's Avatar
yeah i get that too, it squeaks right when you lift your weight outta the car right? My mechanic friends couldn't figure it out either...
Old Jan 27, 2009 | 04:27 PM
daffy12's Avatar
same here. only when i get out of the car.....its the passenger rear. and im lowered on H-techs...wonder what the hell it is
Old Jan 29, 2009 | 06:58 PM
domincnTC's Avatar
cant figure it out either ... also lowered on h techs
Old Jan 29, 2009 | 08:59 PM
Tofu_Racer's Avatar
I've got the same problem also. Mine was lowered with Eibach Prokit springs and TRD struts. That's a drop of about only 1.5". I don't know what it is...it's coming from the passenger rear side.
I weigh about 135 lbs. and I hear it when coming in and out of the car. Especially loud during cold weather.
I think it might be the whole rear end frame of the car.
Old Jan 29, 2009 | 09:10 PM
axleback_tc's Avatar
i get that same squeek holy ____ i thought i was the only wtf is that man im thinkin maby its the strut tower bolts are rubbin against the body and its makin it squeek
Old Mar 31, 2009 | 05:02 AM
Lester4's Avatar
I also have a sqweaking noise, I installed the Hotchkis front & rear sway bars on my '08 tC and I greased them both, but a few days after I satrted hearing a sqweaking noise from the front sway bar, bushings I believe, everytime I go over a speed bump. What should I do about this bugging problem??
Old Mar 31, 2009 | 07:13 AM
JOEinSD's Avatar
My car creaks when I get out of my car too. And I only weigh 118lbs.!!!
Old Mar 31, 2009 | 12:23 PM
NYNCTC's Avatar
i just installed my h-techs a few days ago. this morning i heard a whistling noise but havent heard a squeaking noise. i guess ill let you know when i do haha.
ilovemytC
Apr 24, 2007 11:13 PM
scvscions
Regional - Pacific South
Nov 6, 2006 07:07 PM
scvscions
Nov 6, 2006 05:48 AM
scvscions
19
Dec 9, 2005 12:54 PM
scvscions
Dec 6, 2005 01:33 AM
