The Mysterious Sqweak..Continues....
Okay...SO I had a High Pitch Sqweak coming from the Passenger Rear Spring...Becuz every Bump I went over made a High Pitch Noise...
To fix it I took apart the Rear Suspension and wrapped the last coil w/ a rubber Tire Tube from a Bicycle. That fixed that Sqweak Noise!
Now a NEW Sqweak developed!...It only happens when I get In & Out of the car!!...
Adjusted E-Brake too!
I tried to Re-Grease the Rear Sway Bar bushing too...That did not work!
Where is this sound coming from??????
I will appreciate if someone could shed some light on this Noise issue!!!..Its Annoying!!
Thanks again in Advance!
Originally Posted by domincnTC
cant figure it out either ... also lowered on h techs
I weigh about 135 lbs. and I hear it when coming in and out of the car. Especially loud during cold weather.
I think it might be the whole rear end frame of the car.
I also have a sqweaking noise, I installed the Hotchkis front & rear sway bars on my '08 tC and I greased them both, but a few days after I satrted hearing a sqweaking noise from the front sway bar, bushings I believe, everytime I go over a speed bump. What should I do about this bugging problem??
