flat black stockies on bsp tc
Old Jan 27, 2009 | 02:52 AM
jefffribourg's Avatar
Default flat black stockies on bsp tc
i bought
- high heat primer x4
- duplicolor flat black x4
- duplicolor clear coat x2
- sand paper x1
- scotch blue painters tape x1
is there anything else that i need to buy?
and is this going to look good color wise?
if anyone has pics of their stockies flat blacked send them please!
Old Jan 27, 2009 | 02:56 AM
tri856's Avatar
why so much primer and paint? and theres no need for tape. you use index cards they work much better and save time from taping the tires. for paint and primer all you need is 2 cans each and for the paint you should get wheel paint becaseu wheel paint is better and doesnt chip as easy.and i would get like 3 cans of clear coat becuase its just better.
Old Jan 27, 2009 | 03:06 AM
KrazyAznScion's Avatar
dude.. looks like the amount you spent on materials you could have just gone and have sum1 powder coated them..
Old Jan 27, 2009 | 03:09 AM
all the paint is rim/ automobile paint.
and how much is powdercoating?
i only spent like 50.00
plus will still even look flat when you put the clear coats on?
Old Jan 27, 2009 | 03:12 AM
should normally be about ~150... they're much more durable and lasts longer lol..
Old Jan 27, 2009 | 03:31 AM
damn
well mabey if i get over the black,
i was kinda thinking white might look kinda cool
Old Jan 27, 2009 | 04:16 AM
10PieceNuggets's Avatar
4 cans? Jeez you only need 2 of each as someone stated. The process is rather simple and not as hard as people say, if you can spray paint some rims then you fail at life, just index card the wheel, sand a little bit and have fun painting. Clearcoat may give you a shine but I didnt put any clearcoat on my painted super sevens and they have no shine to them at all. I put like 3 heavy layers and its holding up fine.
Old Jan 27, 2009 | 04:24 AM
mystik's Avatar
CinSity Scions
well there's diff types of clear coats. i know mine was non-gloss from when i spray painted the little chrome trim around the front upper grill flat black...though i probably should redo it now, rock chips owned it up
Old Jan 27, 2009 | 04:55 AM
http://i9.photobucket.com/albums/a10...ver/Photo5.jpg
these are the paints
the clear coat says on the back that it will leave a glassy finish, but if the color is flat black then will it look flat with a shine?
i just dont want it to look like cheap spray black
Old Jan 27, 2009 | 07:41 AM
BlkTC's Avatar
just don't put on a clear.. lol
anytime it chips.. spray a little primer and voila..
just messin... you should be fine.. test out your clear coat first.. spray some black and spray the clear over it.. just find a piece of metal in your garage or something...
Old Jan 27, 2009 | 03:35 PM
tri856's Avatar
u need acetone to clean ur wheels after
Old Jan 27, 2009 | 06:24 PM
ahatch133's Avatar
do it in a hot dry place let them sit
Old Jan 27, 2009 | 06:47 PM
Jlowe's Avatar
I used 1 can of primer on mine,
and 1.5 cans of dupliccolor wheel paint. And I did 3 coats of regular paint. Doesn't come off at all.
Old Jan 27, 2009 | 07:07 PM
jsingh's Avatar
OhioScions
wouldn't the acrylic lacquer bubble/messed up the black paint since its not acrylic?...bec. when i was painting i used regular black paint and i used acrylic lacquer clear and the paint bubbled?
Old Jan 27, 2009 | 08:22 PM
Jlowe's Avatar
Sorry, by regular I meant the wheel paint not primer.
I got 3 nice smooth coats out of 1.5 cans. I did 3 coats of black
1 coat of primer.
I didn't clear, and it hasn't chipped off in the 2 weeks i've had them on (3 painted) but if it does, ill repaint and clear.
Old Jan 28, 2009 | 07:01 AM
why did the clear bubble?
do they make another claeer coat?
adorable
Mar 9, 2016 04:03 PM
stenger
Mar 29, 2015 08:03 AM
Max
464
May 20, 2013 06:32 PM
happies713
10
Dec 22, 2003 12:27 AM
LVXB
15
Dec 7, 2003 12:47 AM
