Looking for a one touch sunroof full open mod
Old Feb 1, 2009 | 01:02 AM
b52hDUNN's Avatar
Default Looking for a one touch sunroof full open mod
Has anyone seen anything on how to mod the sunroof switch to open all the way by pressing the switch once instead of holding it down? I did a mod like this to my 05 corolla XRS a couple of years ago.
Old Feb 1, 2009 | 12:25 PM
ValenciaS's Avatar
hmm intersestinig, would love to find a mod also.
Old Feb 1, 2009 | 05:24 PM
all4degame's Avatar
just buy a rocker switch and wire it up to the sunroof connector. its as simple as that.
Old Feb 2, 2009 | 05:21 AM
TcPrincess's Avatar
no its not that simple. that will keep the motor on all the time which will chew up the tracks.
Old Feb 2, 2009 | 05:31 AM
all4degame's Avatar
ummm..flip it back when its fully open? uhh. yeah.
Old Feb 2, 2009 | 05:40 AM
TcPrincess's Avatar
well if your still going to have to dick around with a switch then why not just keep the original on? i'm pretty sure he's looking for a one touch system. uhh yeah.
Old Feb 2, 2009 | 06:01 AM
equinox2355's Avatar
This might help, found some info on this site: http://ourworld.compuserve.com/homep...tm#relay_i.gif
Power-Off Time Delay Relay
The two circuits below illustrate opening a relay contact a short time after the ignition or ligh switch is turned off. The capacitor is charged and the relay is closed when the voltage at the diode anode rises to +12 volts. The circuit on the left is a common collector or emitter follower and has the advantage of one less part since a resistor is not needed in series with the transistor base. However the voltage across the relay coil will be two diode drops less than the supply voltage, or about 11 volts for a 12.5 volt input. The common emitter configuration on the right offers the advantage of the full supply voltage across the load for most of the delay time, which makes the relay pull-in and drop-out voltages less of a concern but requires an extra resistor in series with transistor base. The common emitter (circuit on the right) is the better circuit since the series base resistor can be selected to obtain the desired delay time whereas the capacitor must be selected for the common collector (or an additional resistor used in parallel with the capacitor). The time delay for the common emitter will be approximately 3 time constants or 3*R*C. The capacitor/resistor values can be worked out from the relay coil current and transistor gain. For example a 120 ohm relay coil will draw 100 mA at 12 volts and assumming a transistor gain of 30, the base current will be 100/30 = 3 mA. The voltage across the resistor will be the supply voltage minus two diode drops or 12-1.4 = 10.6. The resistor value will be the voltage/current = 10.6/0.003 = 3533 or about 3.6K. The capacitor value for a 15 second delay will be 15/3R = 1327 uF. We can use a standard 1000 uF capacitor and increase the resistor proportionally to get 15 seconds.
MRE
Feb 16, 2016 11:26 PM
kahsperr
Regional - Pacific South
Mar 26, 2015 06:25 PM
CPL_Radar
Mar 5, 2015 05:42 AM
gularti
Dec 4, 2014 01:21 PM
