better handling, stock height
Old Feb 3, 2009 | 03:09 PM
markmscion's Avatar
Default better handling, stock height
I am looking to get better handling while retaining the stock ground clearance. (I live on a bumpy dirt road and don't want to be dragging the bottom of the car on the ground)
So, I am thinking:
TRD rear sway bar
front strut tower brace?
Better rear shocks?
Anyone know of better rear shocks that will work with the stock ride height?
Mark
Old Feb 3, 2009 | 03:50 PM
FromTheOld's Avatar
Default Re: better handling, stock height
So, I am thinking:
TRD rear sway bar
Better rear shocks?
Mark
Hotchkis Stabilizer Set
Front Strut Tower Bar
Upgrading shocks is not worth it, especially if you only want the rear ones. I don't think aftermarket springs really help handling much, if at all, and I feel that people only buy them to lower the car (and lower does not always mean better for handling). An underbrace would help, but it would be the lowest part of the car and it would bottom out all over the place. If you want to go one step further, you can buy coilovers and keep it at stock height.
Old Feb 3, 2009 | 03:55 PM
a_german_named_hans's Avatar
as far as tcs go, Rear sway. Front strut tower bar does near nothing. I guess shocks/struts would help as well since they would stiffen up the ride but i have no personal experience in this area, I'm still on stock struts. And lowering springs do help with handling, its a combination or the higher spring rate and lower center of gravity.
Old Feb 3, 2009 | 04:29 PM
FromTheOld's Avatar
Strut bars actually help on cars with Macpherson Struts, like the tC/xB.
Lowering springs "lower center of gravity" is better, but most lowering springs lower past the acceptable limit of Macpherson Struts which causes negative handling characteristics. If you lower the car, the lower control arms will be positioned upward and when you enter the corner, the car's outside tire will roll into positive camber.
Not to mention some aftermarket springs are similar in spring rate to stock, if not softer, not to mention they are of progressive design. Progressive design is okay for comfort (but properly valved dampers matched with the springs are just as comfortable) but not for racing/handling unless you only take turns fast occasionally.
Old Feb 4, 2009 | 09:56 AM
srb219's Avatar
"Old" I agree, strut bars do help our cars but you would have to push cornering G's to the limit to realize any benefit. Again agree with your comment about roll center and postive camber (bad). Surely TRD knows this so maybe small drop, 1" or so is not that bad.
Old Feb 4, 2009 | 11:46 AM
FromTheOld's Avatar
Yeah, the acceptable lowering limit on Macpherson Strut cars is a 1 inch drop, which is why I think TRD springs are the only good springs for our car
Old Feb 4, 2009 | 05:50 PM
DAILYXB-TYPE-R's Avatar
well if you have a roll center adjuster it well help correct the steering if you drop your car too much 1.5"+
i've been searching for sooooo long and still haven't find anything about it yet for our car.
i used to have a 2007 honda fit and i got the roll center adjuster install after i put some coil over and it really did help stablize the car in corners. here's a link to what i got for my fit.
http://www.aj-racing.com/shop/produc...cat=471&page=1
damn i miss my fit
SloTC1
Apr 2, 2015 07:11 PM
XBEEZY
Scion xB 2nd-Gen Wheel & Tire
Feb 21, 2015 01:38 PM
carid
Feb 12, 2015 11:54 AM
ploniaczysko
Scion tC 1G Wheel & Tire
Jan 28, 2015 02:15 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
