Will these Enkei rim/tires fit?
Old Feb 3, 2009 | 09:02 PM
Greygooser's Avatar
Default Will these Enkei rim/tires fit?
Hey all, new 2004 xB owner here, rolling on studded snows till Spring. (the xb rips through snow with these)
Anyway, I started my shopping for summer wheels, and found some 18 Enkei's with tires for a good price. With a 45 offset, not sure if they'll fit. Here are the full specs:
225/40/18
18 x 7.5 with a 45 mm offset
and obviously, a 4 x 100 mm lug pattern.
I understand I may need a spacer, but will that do the trick? Any thoughts are appreciated, I'm a dullard when it comes to wheels.
Old Feb 4, 2009 | 03:29 AM
sdsnybny's Avatar
If your at stock height the 40's will work but if you drop it any they will rub. Most use 35's on eighteens to clear if dropped. An 8 inch wide +40 wont clear control arm nub in rear, a 71/2 +45 sits back the same distance you will need at least 5mm spacer in rear to fit. a +35 would sit more flush to fender and not needa spacer
Fronts should be fine +40 or +35.
Here is a good site to compare wheel specs
http://www.rims-n-tires.com/rt_specs.jsp
Onestepahead85
Apr 28, 2015 07:05 PM
InfinitXA
Apr 8, 2015 07:53 AM
paul_dezod
Scion tC 1G Wheel & Tire
Dec 10, 2014 06:46 PM
DR_xB
Jul 20, 2004 08:31 PM
