Autometer Tach install on 06 Scion xB
Old Feb 4, 2009 | 03:01 AM
MIKECLARK1000's Avatar
Default Autometer Tach install on 06 Scion xB
I need help. Haven't a clue on what would be the best way to install my Autometer tach on my xB. Does anyone have any experience or help so i caN GET THIS INSTALLED.
Old Feb 4, 2009 | 04:20 AM
Sciond's Avatar
moved for help
Old Feb 6, 2009 | 01:29 AM
greenguyshrek's Avatar
Here is some info:
On most tach there are 4 wires.
Green wire that is for the tach signal
Black Wire for ground
Red wire for Power to gauge
White wire for ligths for gauge
On these cars the OBDII scanner port is just under the dash 16 pin connector. first pin on bottom row, left to right is for the tachometer. The rest of the wires go on the fuse box. Ground wire attacth to good metal ground under dash. Hook the wire that turns on the gauge to the ACC fuse. . And hook up the wire for the lights tp your taillight fuse. Be careful, Make sure you connect this right or you might screw up your car.
Hope this helps
IrjI619
Jan 28, 2015 05:21 AM
IrjI619
Dec 21, 2014 05:04 AM
JM Auto Racing
Dec 19, 2014 06:36 PM
abbfanuc
Jul 19, 2007 12:16 PM
racingtoys
Dec 4, 2003 10:34 PM
