In need of help for stereo questions
Old Feb 6, 2009 | 09:57 PM
AudioPhill's Avatar
Default In need of help for stereo questions
Hello, I didn't see a better place to put this but I'm not the greatest at navigating forums. Here's the things that I need help with.
I want to use a DEH-P800PRS Head unit but cant figure out which install kit to use that will allow me to continue to use the door over the head unit. The American International TOY-K969 looks like it would work and one review on Crutchfield says it allows enough recess for the door to function properly but it doesn't say what kind of deck he used (whether or not it had protruding *****.) Also, Id like to know where people are bringing their power cable for amps through the firewall. I can take it from there, plenty of experience with install, this car is an anomoly in design for easy deck exchange.
Old Feb 8, 2009 | 08:47 AM
AudioPhill's Avatar
Default Nobody
Come on people, surely someone has 30 secs to type an answer and get me going?
Old Feb 8, 2009 | 12:06 PM
landark's Avatar
I have an older version of the same h/u. The volume **** does stick out some, but nothing that will interfere with closing the door. Any install kit that is for a tC should be fine.
I ran my power cable through the grommet around the steering column.
Old Feb 8, 2009 | 07:21 PM
AudioPhill's Avatar
Default Any Install Kit
Have you ran a power wire through the firewall?
Old Feb 8, 2009 | 07:45 PM
yellowxhoodie's Avatar
if the HU doesnt fit all you have to do is drill new holes in the mounting bracket so the HU sits farther back.
for the power line you can actually run it up the side on the engine bay and through the door jam.
Old Feb 8, 2009 | 08:28 PM
AudioPhill's Avatar
Default Dor Jam
I want it completely hidden like the guys setup with the pics of the scion tear down where he put damping in it. Toy's usually have a grommet that allows for easy firewall pass through but the tc wasn't that thought out.
Old Feb 8, 2009 | 10:06 PM
well like i said, if it doesnt fit modify the bracket and/or trim the backside of the door with a dremel in the area its hitting.
and theres are severel grommets in our firewall, go outside, pop your hood, and look.
Old Feb 8, 2009 | 10:11 PM
TwztedtC's Avatar
how can you suggest running a power wire through the door jam that could cause a serious problem if the insulation wears through to the bare wire.
Old Feb 9, 2009 | 01:25 AM
x_Batman_x's Avatar
yeah yellow for how clean you usually go about installs and custom work, I'm surprised you would advocate cheaping out and using the door jamb...
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
