wheel hop issue
Old Feb 13, 2009 | 06:00 AM
scionkei's Avatar
Default wheel hop issue
whats the best way to help eliminate the wheel hop issue in the tc? i've thought about putting in polyurethane motor mounts and tranny mounts, along with some stiffer struts, front and rear anti sway bars, and potentially a torque dampener. any other ideas on how to curb this? i don't want to do lowering springs. i dont want to mess with those right now. anything that can help without changing the alignment, toe or camber would be of great info to me.
Old Feb 13, 2009 | 06:02 AM
rosedaleny806's Avatar
motor mounts, ETD, LSD
Old Feb 13, 2009 | 06:53 AM
scionkei's Avatar
sorry whats an ETD? not familiar with that terminology.
Old Feb 13, 2009 | 06:55 AM
scionkei's Avatar
Lsd is out of my budget, try too keep within $400 a part. sorry for not being more clear.
Old Feb 13, 2009 | 06:59 AM
itlstl13's Avatar
ETD= Engine Torque Damper ..... i heard they give kind of a rough ride tho since ull be feeling all of the engine vibrations
Old Feb 13, 2009 | 07:04 AM
engine torque damper. basically an apparatus that connects ur engine to ur strut on the passenger side. goes for about 100 bucks used on here, weapon-r and DME makes them, aswell as cheap ebay ones. even though it works ok, its jus basically a minor fix for wheel hop. to really make a difference I'd add an ETD and motor mounts. the downfall to this is that it makes a HORRIBLE cabin noise from metal on metal rubbing even with motormounts it cause a lot of vibration to be moved around in the cabin cause of the engine being held in place stiffer.
Old Feb 13, 2009 | 09:11 AM
sciontc_mich's Avatar
here's a cheaper solution, better tires = more traction = less wheel hop.
I bet you're using the stock tires right now.
try nitto neo gens, that you could get a set for about $400.
Old Feb 13, 2009 | 10:06 AM
tcCALI's Avatar
^ a new "nice" set of tires would not be cheaper then and ETD or MM.
Old Feb 13, 2009 | 02:18 PM
09tC_CB7's Avatar
ETD would probably be the easiest to install. I have heard the rear (I think) engine bushing is hard to get to.
But tires would probably be the best option, because the stock ones are not that great. Plus sticker tires help in the corners.
Old Feb 13, 2009 | 02:22 PM
SW_08's Avatar
i think im gonna start with new tires too....and if im not satisfied with that LSD here i come....
Old Feb 13, 2009 | 02:27 PM
Akrylic09's Avatar
Dont peeel out?
/wheel hop
Old Feb 13, 2009 | 03:49 PM
enjoithis's Avatar
Energy Suspension motor mounts.
Old Feb 13, 2009 | 03:55 PM
SW_08's Avatar
a friend told me about those b4.....
how are they....do u have them??
Old Feb 13, 2009 | 03:57 PM
enjoithis's Avatar
Yes, I have them, have some in stock too. IMO these perform better than the ETD. Reason people use the ETD over mounts is because of the install, mounts can be quite a headache without the right tools, but a local shop can do these rather easiliy. Even if you can get the front mounts in you are ahead of the game. Great mod for the price!
Old Feb 13, 2009 | 04:00 PM
SW_08's Avatar
thanks for the info...
Old Feb 13, 2009 | 04:03 PM
enjoithis's Avatar
Also wanted to add- Mild lowering springs like H-Techs or TRD springs are not enough of a drop to screw up your alignment. If your worried about doing struts, sway bars, motor mounts, etc, the drop would be first on my list. It will not reduce wheel hop but it will change the overall look and ride of the car (for the better)
Old Feb 13, 2009 | 04:09 PM
SW_08's Avatar
i have a trd drop with hotickis sways already on my tc thanks for the tip tho.....
Old Feb 13, 2009 | 04:15 PM
CSOCSO's Avatar
that wont make too much different.. i had falken 452 tires.. now i have kumho ecsta spt and still got plenty of wheel hop. wheels would be my LAAAAST choice in eliminating the wheel hop
Old Feb 13, 2009 | 04:39 PM
limptc's Avatar
lower the psi in your tires =P
Old Feb 13, 2009 | 05:21 PM
enjoithis's Avatar
Nitto Neo Gens on my car - Before mounts i still got some wheel hop, but with mounts virtually none. It does make a difference, but IMO Energy Mounts FTW
