Fuel Return Alternative? need opinions on this.
Old Feb 13, 2009 | 08:00 AM
SoFloTC's Avatar
Default Fuel Return Alternative? need opinions on this.
Ok so my tuner and i were speaking about what to do after we get the tranny swap squared away.. were puttin the filter directly on the turbo, running a blow-by maf, and an intake mani came to mind and then we got to the fuel.. he said on a couple big turbo built subbies and is300's that hes done to solve the problem for a fuel return system he actually tapped another feed line right into the stock fuel rail in the middle so it was like dual feed. He said i could run stock rail and make a return setup with a fuel pressure regulator.. what do you guys think?
Old Feb 13, 2009 | 01:52 PM
ElevationTC's Avatar
1st ,How much power are you running
2nd what size injectors.
what are your current fuel mods?
Old Feb 13, 2009 | 02:00 PM
yamaha16bw's Avatar
Sounds to me your going to end up buying a pump, lines, fittings anyway plus the cost of welding on a fitting to the stock rail.
Why not just buy a rail and a FPR? Plus the stock rail is tiny. It will only take you so far.
Old Feb 13, 2009 | 03:14 PM
Crayola_G's Avatar
luigi was gona do this to my rail man T it off sounds good...take pics!
Old Feb 13, 2009 | 03:19 PM
fuel rails can be bought for around 150.00 shipped.. imo well worth it
Old Feb 13, 2009 | 04:55 PM
SoFloTC's Avatar
im looking to push 450.
im on 700's right now on 15 lbs and there no where near maxed out.
i got a walbro pump thats it lol.. thats what i was saying tap the stock rail and do a custom return with a pressure regulator and the welding on the stock rail would be free im not worried about that, im just wondering if this would work?
Old Feb 13, 2009 | 05:04 PM
not sure what running a second line is going to do?
Our internal FPR is going to limit you to say 43.7 psi...
if your going to run a second line to your tank why wouldint you just do the return line?
Old Feb 13, 2009 | 05:07 PM
SoFloTC's Avatar
i am planning on doing the return setup aswell.. im just saying instead of buying a new rail i can just dual tap the stock one..
Old Feb 13, 2009 | 05:28 PM
you have came this far.. As i watched your progress. which has been amazing btw mad props..
Why even chance it?
Old Feb 13, 2009 | 05:40 PM
SoFloTC's Avatar
haha cuz its costing me an arm and a leg to do the manual swap and buying an intake mani now all i need for 450whp is a stupid fuel return setup lmao
Old Feb 13, 2009 | 05:44 PM
i hear you bro! Im in the same boat.. Personally wouldint even buy the intake manifold if i were you.. Stock one works fine.. I would rather see you build a really bad ___ fuel system..
Old Feb 13, 2009 | 05:46 PM
toyota_scion_tc's Avatar
I wouldn't waste money on an intake manifold until someone can provide a dyno stock compared to the new one. The stock one is well built and even though its plastic I haven't heard of a lot of people blowing it. I think Ptuning is still running the stock one without issue. Not to mention aftermarket one you will have to worry about heat soak.
Old Feb 13, 2009 | 05:49 PM
Well said thanks for the back up statement..
Invest in better fuel!
Old Feb 13, 2009 | 05:50 PM
SoFloTC's Avatar
hmm u think the stock one will hold up 18-20 lbs? DD
Old Feb 13, 2009 | 05:55 PM
i think somewere i remember reading it held some were around 30 pounds or so...
ill be running almost 23 pounds on mine..
Old Feb 13, 2009 | 06:02 PM
SoFloTC's Avatar
damn thats alot.. i think at 18 lbs ill easily be over 400 or at it so.
I know someone that has these for sell, I can find out his price I think it is cheaper than 150 and they are annodized, but limited colors are available red, black, and maybe blue. If intrested let me know so I can contact him for you. They have -6AN fittings I believe. I am running this fuel rail on my tC's return fuel setup.
yamaha16bw's Avatar
Yup a good fuel setup will end up costing close to 1000 bucks.
Old Feb 13, 2009 | 06:09 PM
Assuming you have a well built turbo setup and the bov or bov’s (not sure how much one could release could be possible to need a really big one or two if the setup is extreme enough) can release that much pressure I don’t think you will have an issue with 18-23.
And thats w.o injectors
