High current battery
Old Feb 14, 2009 | 06:19 PM
1vicissitude's Avatar
Default High current battery
Okay so I finally istalled my system and now need to replace my battery as my lights are dimming slightly on lower bass notes. The dumb shop I went to used a distribution block with a agu fuse type so I cant turn the volume up past 1/3 for right now without blowing a 100amp fuse. I am working with them to replace it with an anl distributioon block but I'd imagine with volume at 1/3 and my lights are dimming I am going to have some real issues once the fuse situatioon is resolved.
I origanolly wanted a kinetic hc1800 as they fit perfect in the oem spot and have nice ratings. The shop told me they are not good to use as a cranking battery and recommended an optima yellow top. Which would be better? After the fuse problem I dont really trust thier knowledge.
What battery would you guys recommend for about 1600-1700 watts rms total system wattage? Also should I add the battery ontop of what I've got, or just swap the factory spot? I dont think I will be adding much more to the system in the near future as I'm happy for now with what I've got.
Old Feb 14, 2009 | 10:05 PM
SanchezHacker's Avatar
I'm probably wrong here, but wouldn't a capacitor fix your problem of dimming headlight? Also, I hear if your system draws enough current to warrant a new battery then you probably need a new more powerful alternator.
Sorry but I've never dealt with systems of that many watts before, so I'm not sure if my advice is good or not.
Old Feb 15, 2009 | 04:50 AM
Yeah A capacitor would help but they are more of a bandaid. I feel they only have thier place in helping with the really deep notes as they can dump thier power reserves very fast. A cap would be nice but I think I will look into one after the problem of actually having enough power is resolved.
An alternator would be great, but for my current power consumption I think getting one might be a bit of overkill.
I'm really hopeing someone can chime in as to whether the kinetics are okay to use as a cranking battery.
Old Feb 15, 2009 | 04:52 AM
equinox2355's Avatar
Upgrade the big 3 first
http://www.isyougeekedup.com/the-big...iring-upgrade/
as a side note, I was planning on getting the Kinetik HC1400 Power Cell and using it as a cranking battery (was told by a few friends that after the big 3 are upgraded, the Kinetik battery works fine for cranking and everything else)
Old Feb 15, 2009 | 06:15 AM
buickid's Avatar
The Kinetik is designed to dump massive amounts of current, which is exactly what the starter requires. A cap likely won't do anything for your system, if its to the point that your headlights are dimming. Get a battery, put it under the hood, wire EVERYTHING up in 1/0, and put another battery under the passenger seat. You shouldn't have much problems with dimming after that, if you are, then you definitely need an alt. Heres a link to my BIG 3 install, it includes great pictures. I have a Optima D31T under the passenger seat, with the stock battery under the hood, though disconnected. I keep it there in case I ever kill the Optima, and need to get somewhere. Feel free to ask questions! Better to do it right.
MRE
Feb 16, 2016 11:26 PM
bktply
Mar 17, 2015 04:50 AM
mvez
Scion tC 2G Aero & Exterior
Feb 4, 2015 01:15 AM
DynamiteSJ
10
Nov 2, 2003 01:25 AM
