The shine is gone!
Old Feb 16, 2009 | 05:12 PM
chizzz7's Avatar
Default The shine is gone!
so i just tinted my tailights using vht nightshades and after the clearcoat i sanded it down. I used rubbing compound with a buffer for 2 coats on each tailight, and then 2 coats of plast-x and after that i used 2 coats of wax, but the shine is still not there. My tailights are still kind of a flat black color and only show some shine. It really looks ugly because the flat black sticks out in contrast to the shininess of the rest of the car. Should i just keep applying coats?
Old Feb 16, 2009 | 05:16 PM
B_Real45's Avatar
What grit did you sand it down with? And did you do a wet-sand?
You're supposed to wet-sand clearcoat with atleast 1500 grit.
Old Feb 16, 2009 | 05:24 PM
chizzz7's Avatar
i wetsanded with 2000 first and then 1000 for the heavier orange peel
Old Feb 16, 2009 | 05:25 PM
B_Real45's Avatar
The ending with the 1000 grit is what killed you.
You need to do that first.. then work your way up to 2000 grit.
Old Feb 16, 2009 | 05:59 PM
chizzz7's Avatar
oh ok. . . . so if i sand with 2000 grit now then it should look ok?
Old Feb 16, 2009 | 06:00 PM
B_Real45's Avatar
Yeah if you haven't sanded down all of the clearcoat yet.
I would do 1500 then 2000 both wet. Then you can go polish your arms off.
Old Feb 16, 2009 | 06:18 PM
chizzz7's Avatar
ok sweet ill do that. . . .and if worse comes to worse can i just add a clear coat and not sand it. . .because it looks pretty good just like that too
Old Feb 17, 2009 | 02:11 AM
FLEA's Avatar
The fact that you don't know what to sand with just means you shouldn't be doing this at all.
Not trying to sound like an a$$ but there are MULTIPLE threads on here that show you how to properly do it. You never sand with 1000 grit unless you are experienced with it. Always use the least aggressive approach first.
Old Feb 18, 2009 | 02:33 AM
impa105817's Avatar
yea i learned the hard way dont try to do stuff you have no idea how to do
Old Feb 18, 2009 | 04:40 PM
BlckdOutTC's Avatar
happened to my first set of tails i ever smoked. wet sand them, re clear them, wetsand and then buff with a good rubbing compound. I first tried the turtle wax crap and didnt work, but the 3M stuff works wonders, then throw on some wax to protect it
Old Feb 20, 2009 | 04:52 AM
chizzz7's Avatar
Hey i used turtle wax rubbing compound. . .do u think if i would have used 3m that it would have worked properly?
Old Feb 20, 2009 | 01:28 PM
B_Real45's Avatar
First did you redo your wetsand? The 1000 grit is not a good ending sand.. you needed the higher grit sand for a finish.. then do the polish and wax.
Old Feb 20, 2009 | 02:46 PM
BlckdOutTC's Avatar
what kind of clear coat did you use?
Old Feb 20, 2009 | 07:31 PM
ElevationTC's Avatar
At this point use 1000 grit smooth it out and recoat it.. Be careful it dont lift now ..
Like mentioned before for best results you shoulda taken it to a pro..
I have people come in all the time with things they try to do them selves.. In the end its cheaper for me to do it to begin with then fix others mistakes!
Old Feb 20, 2009 | 07:35 PM
B_Real45's Avatar
Yes a pro would have been the easy solution..
However it was logic that failed here. You have to work on orange peel first, then recoat, then finish wet sand with a very high grit. After all this you can polish and wax.
Old Feb 20, 2009 | 11:13 PM
chizzz7's Avatar
thanks everyone for the help Next time ill go to the pros.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
J_Pauley_Scion
Jun 12, 2005 03:57 PM
J_Pauley_Scion
Jun 12, 2005 03:56 PM
