Rear Spolier
Old Feb 18, 2009 | 01:00 PM
gkccbc00's Avatar
Default Rear Spolier
Without drilling into the back hatch, what could I use to mount the rear spoiler? Need advice on what kind of tape to use
Old Feb 18, 2009 | 01:28 PM
spr0k3t's Avatar
If you are just going to use tape, there's a real strong double sided tape used in racing. It's even better than the 3M red exterior tape. For the OEM spoiler, I'd still recommend drilling and sealing though. If you do tape only, make sure the temps of the metal, spoiler, and tape are all above 72ºF for maximum effectiveness.
Old Feb 18, 2009 | 02:04 PM
TypeX's Avatar
I dont really see why you wouldn't WANT to put the screws in.
Install is cake and takes literally 20-30 minutes.
vs
The risk of catching some windy day and it flying off and killing someone lol
or a thug kid pulling it off and jacking it.
ANYWHO....
https://www.scionlife.com/forums/viewtopic.php?t=248073
tons of + and -'s listed in the above (and was on page one)
Old Feb 18, 2009 | 02:16 PM
iceboxx5's Avatar
I live in va i will install it for you for 40$.I work for toyota.
Old Feb 18, 2009 | 02:52 PM
burstaneurysm's Avatar
I 3M taped mine on. The tape is starting to give way a little. It's still solid, but it looks kinda weird.
I'm drilling the top holes this spring.
Old Feb 19, 2009 | 02:51 AM
Metro273's Avatar
^^^Drill that badboy on!
Old Feb 19, 2009 | 03:14 PM
Skuff_Box's Avatar
Drill plus 3M tape
Old Feb 21, 2009 | 01:41 PM
MadMike550's Avatar
I'd be happy to istall it for you...free of course
you can look at mine first if you would like
Old Feb 21, 2009 | 01:50 PM
MadMike550's Avatar
actually you do need the templates and hardware kit..
2 plastic inserts and 2 rubber bolt ancors
did you take off the 2 plastic nipples that were installed on your spoiler?
they are supposed to fit into the plastic inserts..which are supposed to be mounted on the verticle surface of th rear hatch
Old Feb 26, 2009 | 04:35 PM
ajayaitch's Avatar
3M taped for coming up on 2 years. No lifting.
Old Feb 26, 2009 | 06:29 PM
bdmcleod's Avatar
Never had a problem with mine. I used 3m tape.
Old Feb 26, 2009 | 07:28 PM
vettereddie's Avatar
Got the spoiler in with all hardware, so I drilled. Was hella nervous though putting a bit to new paint.
After you put up the template AND check it's right, use a metal punch to make a small divot so the drill bit won't walk.
Old Mar 3, 2009 | 06:45 PM
boxman27's Avatar
did you get your spoiler from a dealer? and did i come with the template? i would like to put one on the box but i also would be a little nervous about drilling on my car
Old Mar 3, 2009 | 07:22 PM
I removed the two nipples. I have the hardware floating around still, but no template. I might just try re-taping it.
Old Mar 3, 2009 | 08:59 PM
MadMike550's Avatar
I still have the templates..find your hardware
and let me know
I can either do it for you or send you the templates
Old Mar 3, 2009 | 09:32 PM
Where in WI are you?
Old Mar 4, 2009 | 02:04 PM
MadMike550's Avatar
right across the border..
Kenosha
Old Mar 4, 2009 | 02:36 PM
I might take you up on that...
Old Mar 4, 2009 | 03:00 PM
MadMike550's Avatar
it's up to you..
just let me know...
toyotaisme
Jan 10, 2015 10:24 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
umnitza
Dec 1, 2014 06:26 PM
crystaljukebox_com
39
May 14, 2004 04:55 AM
