Rear Spolier
If you are just going to use tape, there's a real strong double sided tape used in racing. It's even better than the 3M red exterior tape. For the OEM spoiler, I'd still recommend drilling and sealing though. If you do tape only, make sure the temps of the metal, spoiler, and tape are all above 72ºF for maximum effectiveness.
I dont really see why you wouldn't WANT to put the screws in.
Install is cake and takes literally 20-30 minutes.
vs
The risk of catching some windy day and it flying off and killing someone lol
or a thug kid pulling it off and jacking it.
ANYWHO....
https://www.scionlife.com/forums/viewtopic.php?t=248073
tons of + and -'s listed in the above (and was on page one)
vs
ANYWHO....
Originally Posted by burstaneurysm
I 3M taped mine on. The tape is starting to give way a little. It's still solid, but it looks kinda weird.
I'm drilling the top holes this spring.
you can look at mine first if you would like
actually you do need the templates and hardware kit..
2 plastic inserts and 2 rubber bolt ancors
did you take off the 2 plastic nipples that were installed on your spoiler?
they are supposed to fit into the plastic inserts..which are supposed to be mounted on the verticle surface of th rear hatch
Got the spoiler in with all hardware, so I drilled. Was hella nervous though putting a bit to new paint.
After you put up the template AND check it's right, use a metal punch to make a small divot so the drill bit won't walk.
and let me know
I can either do it for you or send you the templates
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
umnitza
Dec 1, 2014 06:26 PM
crystaljukebox_com
39
May 14, 2004 04:55 AM
