bit of trouble...
Old Feb 21, 2009 | 06:32 PM
es_05's Avatar
Default bit of trouble...
i have a turbo 06 and all of a sudden it turned off and doesnt want to turn on.. i found out that the main ground on the engine was bouncing around, so i tightened and now the car wont start. i have checked all the fuses on the driver side. I have noticed that i am not getting any spark when i try 2 crank it so i went ahead and changed the crank sensor but its doing the same thing... any help would be greatly appeciated... is thier another fuse or relay somewhere else because the computer seems fine.... thanks es
Old Feb 21, 2009 | 06:40 PM
jsg93085's Avatar
what fuse did you check? the ones in the cabin on the driver's side or the ones under the hood? IMO, i would check all of them esp. the 7.5A ones because it can be hard to determine if they are blown or not...
Old Feb 21, 2009 | 06:51 PM
es_05's Avatar
well i checked the ones on the driver side but im not sure about the one in the hood... where are they located
Old Feb 21, 2009 | 07:04 PM
jsg93085's Avatar
The fuse box under the hood is right next to the battery. It's a small black box that's covered.
Old Feb 21, 2009 | 07:17 PM
rozz-tC's Avatar
Yeah chances are you popped a fuse under the hood. if you do find a blown one, hit up a junkyard. find a tC and grab the fuses, some of the bigger fuses can cost more than you think.
same goes for the relays, they are hard to tell if blown. If nothing stands out as being blown id grab all of them from another tC and swap it all out.
Also, if you have a multimeter you can do an ohms test for continuity on the fuses you cant see in. infinite = blown
Old Feb 21, 2009 | 09:04 PM
es_05's Avatar
thanks im gonna go try that
Old Feb 21, 2009 | 09:14 PM
cmcpride's Avatar
does your engine light indicater light up when key is switched to the on position?
Old Feb 21, 2009 | 11:02 PM
es_05's Avatar
yea it does...
Old Feb 22, 2009 | 04:50 PM
GUNNIST14's Avatar
I take it you already checked you spark plugs. Like the others said it is most likely of fuse blown.
Old Feb 22, 2009 | 09:06 PM
es_05's Avatar
yeah the spark plugs are not getting any spark...
Old Feb 22, 2009 | 09:57 PM
yellowxhoodie's Avatar
change the brown 7.5A fuse under the hood.
its real hard to tell if its broken or not, i had a broken one, didnt know it, found out, replaced it with another one, that one was broken too and i couldnt tell. lol
Old Feb 23, 2009 | 03:48 PM
es_05's Avatar
thanks guys it was a fuse under the hood... go figure lol thanks the cars runnin again!!!!
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
StxArOne
Scion xA Aero & Exterior
Apr 3, 2018 02:22 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
TheDarkGnome
Sep 15, 2015 02:01 AM
prescottn
Sep 13, 2015 09:04 PM
