2 HID kits (HL & FOGS) - Fogs wont work.
Old Feb 23, 2009 | 02:29 PM
velocity_of_superwhite's Avatar
Default 2 HID kits (HL & FOGS) - Fogs wont work.
I've had 6000k HID's in my headlights for about 2 years in my car - never an issue. Last week I finally buy and install my VRD fogs along with a 3000k HID kit. The first night it lit up fine but after that I had to start my car in order to get both Headlights and fogs running. And now 3 days later fogs flicker for a few seconds then turn off - or just wont turn on at all.
Any one else running dual HID kits experience this problem. What I'm concerned with is if it's my battery. If it is I just might upgrade - maybe an optima.
FYI: I've had her since Mile 1 on May 28, 2006. She now has 50,000 miles and on the OEM battery.
Old Feb 23, 2009 | 04:05 PM
enjoithis's Avatar
Sounds like a bad connection for the one light, tighten the ground. You will know when you need a battery because your car wont start
Old Feb 23, 2009 | 04:17 PM
I think i phrased it incorrectly. My headlights (both) come on but my fog lights (both) don't. It seems like there isn't enough juice for the whole car - engine, radio, headlights and fogs.
Old Feb 24, 2009 | 05:59 AM
scion_andrew's Avatar
Relay ?
Old Feb 24, 2009 | 06:25 AM
Oh me, oh my. My problem is most likely worse than I thought. I reverted back to the stock h3 bulbs and the problem persists. Now the fogs come one during idle but turn off as soon as I engage the cluth in first gear. If i'm driving and release the accelerator the fogs come on but turn off as soon as I give it gas. I've had the car for all of it's 50K miles and didn't use the stock relay before. Could it have been damaged or semi fried? If I can't diagnose the problem I'll try bypassing the relay with an after market wire kit connected directly to the wire. Hopefully that works.
Old Feb 24, 2009 | 11:22 PM
Jspec's Avatar
Does anything else in the car dim out when you step on the gas? If so, it could be your alternator that's going. That's a weird situation though because if it's the alternator then everything else should be going out too...
Old Feb 25, 2009 | 12:51 AM
Nothing else just the fogs
mvez
Scion tC 2G Aero & Exterior
Feb 4, 2015 01:15 AM
mischman
Jan 14, 2015 06:07 PM
jaspercanda
Dec 28, 2014 10:09 AM
Basebllstar
Dec 17, 2014 07:30 PM
umnitza
Dec 1, 2014 06:26 PM
