DOH!! I need Help with AEM Wideband!!!
Old Mar 1, 2009 | 09:13 PM
SVicksTC's Avatar
Default DOH!! I need Help with AEM Wideband!!!
Alright well i guess my extra slack of my AEM wideband got a little loose and dangled to the ground and managed to slit two of the wires open and probably got wet, i electrical taped them but my gauge still just reads 14.8 through 14.7-14.9 but nothing else...
Also when your not on the throttle its suppose to not read anything like this --- and it still just stays at 14.7?
Did i fry the gauge or do i just need to redo the wiring?
Need some help here not an electrical guy at all!!!
not really trying to spend another 200 dollars on the gauge
Old Mar 1, 2009 | 09:28 PM
jsg93085's Avatar
you may need a new sensor... the AEM Part # is:
UEGO sensor 30-2001
see if there is a AEM authorized dealer near you and get that part ordered.
Old Mar 1, 2009 | 10:28 PM
rozz-tC's Avatar
Did the wires get cut at all? i would take it off, cutout the bad part of the wire, solder it back together, shrink wrap it. then test it before buying new parts.
If that does fix it then something is shorted out, could be the display or the sensor. start with the cheapest.
Old Mar 2, 2009 | 04:41 PM
SVicksTC's Avatar
ya the wires got cut a little just two of them, def didnt touch but could of got wet.....
Ill start with trying my friends senosr i hope its not the display
Old Mar 4, 2009 | 11:32 AM
Prototype_xB's Avatar
re-run the wiring first and if that dosen't fix it, then buy a new sensor.
Old Mar 4, 2009 | 01:49 PM
Ace83's Avatar
Ronin Scion
yeah i do what they say.. but i think aem sensor is pretty tough though.. my aem sensor harness is fried like all black and melted yet still reads accurate lol
Old Mar 5, 2009 | 04:24 AM
purevision01's Avatar
The wiring is probably a big culprit. The wideband reads slight changes and voltage, and the cuts and exposure to water will change that voltage. As suggested above, cutting out the contaminated wire and SOLDERING not crimping the wires back together should fix. If not, I would not change the sensor, rather I would change the o2 harness. IMO
Old Mar 5, 2009 | 06:07 AM
SVicksTC's Avatar
well when it gets warmer out im going to re-do the wiring and switching the sensor with a buddies to see the problem....
My a/f's have never been out of whack when i drive the car and im only going to drive the car for inspection saturday
getting exempt from emissions suckas i cant believe i only drive my car 5000 miles a year
college blows....
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Nkelly
Sep 7, 2015 05:06 PM
