lightweight pulleys with turbo?
Old Mar 2, 2009 | 04:26 PM
agencytc's Avatar
Default lightweight pulleys with turbo?
Have any of u guys tried lighweight pulleys with a turbo kit I've heard from people not to do it that its bad and from some to do it what's ur guys opinion on that?
Thanks[/i]
Old Mar 2, 2009 | 10:49 PM
rjweitzel's Avatar
i have a lightened crank pully with my turbo kit, works fine i dont see any harm with it
Old Mar 3, 2009 | 12:17 AM
BYeRhONe's Avatar
i ran a pulley with an untunned turbo for half a year and still running
Old Mar 3, 2009 | 01:10 AM
agencytc's Avatar
sweet and u still get the hp gain of course
Old Mar 3, 2009 | 01:22 AM
draxcaliber's Avatar
nothing wrong with them. i've been using a zpi crank pulley for years now.
i think you mis understood though, do not use an underdrive pulley with a supercharger as it would make the supercharger create less boost.
but they work fine.
Old Mar 3, 2009 | 01:48 AM
agencytc's Avatar
o nice do u guys recommend a agency lighweight crank puller i am greddy turbocharged
agencytc's Avatar
Old Mar 3, 2009 | 01:51 AM
unxpectederror's Avatar
i say get the NST pulley kit.. i really like mine
Old Mar 3, 2009 | 02:01 AM
Carlanga's Avatar
NST here, have about 40k miles running the 3 piece set NA and 1k boosted 2 1/2 years all together
Old Mar 3, 2009 | 02:12 AM
agencytc's Avatar
which kit gives more power?
Old Mar 3, 2009 | 04:11 AM
Carlanga's Avatar
in theory the nst 3 piece set is going to get rid of more weight, cuz ur exchanging 3 heavy pieces instead of just one (crank only with most companies)
Old Mar 3, 2009 | 04:45 AM
rozz-tC's Avatar
Ive been running a ZPI pulley since the v2 pulley came out. and have been boost for about 2 years
Old Mar 4, 2009 | 06:32 AM
waterhurley's Avatar
thinkin about doin this when i do the turbo install.
would a throttlebody spacer help me in anyway with a turbo kit? just because its a lightened pulley kit and the spacer for $100. reguardless ill prolly put lightened pulleys on when i throw the turbo in.
mine as well do it all at once
Old Mar 4, 2009 | 03:09 PM
agencytc's Avatar
I would say try it and see what happens. If it works I will do it also
Old Mar 4, 2009 | 04:20 PM
On3Sh0tBlaz3's Avatar
Before i went F/I I wasnt sure if I should keep my pulley on due to all the arguments arguing both sides whether or not it is safe. Couldnt find my stock pulley so decided to just run the kit with the AP Lightweight Crank Pulley on and it seems to be running just fine. There are many others that have this set up too and for much longer than I have and report no problems. The only argument is something to do with the harmonic balancer etc etc... not going to go into it but we will see how this plays out
Old Mar 4, 2009 | 04:39 PM
enjoithis's Avatar
Pulleys do not effect turbo performance at all, they maintain the same gains that they would on a N/A application.
NST provides lightweight and under drive pulleys, as well as light weight water pump and alternator pulleys. I'll be installing these on my car this Sunday.
Old Mar 5, 2009 | 04:19 AM
purevision01's Avatar
No throttle body spacer on forced induction... You want the air to travel the shortest path. Besides the stock intake manifold basically has a spacer built into it, which is one of he main reasons the 2az whistles in vac.
Old Mar 5, 2009 | 06:30 AM
SVicksTC's Avatar
I run the agency power pulley with my turbo setup
Old Mar 5, 2009 | 04:00 PM
THansenite's Avatar
Throttle body spacers do nothing. I have yet to see any proven gains with a throttle body spacer.
Pulleys, however, actually make a difference. I have been turboed for almost a year now and have been running the NST 3 pulley set for nearly as long. They work great and I have seen no ill effects.
Whoever told you they are bad for the tC doesn't know what they are talking about.
Old Mar 9, 2009 | 03:04 AM
agencytc's Avatar
which kit has a bigger hp gain
