Just installed sub/amp. Got some questions...
Old Mar 2, 2009 | 10:58 PM
dundeal67's Avatar
Default Just installed sub/amp. Got some questions...
Just did my first install...took me around 6 hours because I couldnt figure out how to stick the power wire through to firewall and certain screws were on so tight that it took me a while to unscrew. I also took out alot of things that I didnt need to take out...
here is how it looks:
Is that a good place to ground the amp?
Is there sufficient airflow for the amp?
Also, I found a metal piece that came off of the center console when I took it off. I think it came off of the deck cover thing. Can anyone tell me how to put this back? The cover does not go back after I push on it. I have to manually open it up.
Old Mar 2, 2009 | 11:13 PM
Yanki01's Avatar
that peice looks like its from the door hinge, you might need that or you'll have to keep opening it manually.
Old Mar 3, 2009 | 12:13 AM
BZinn1's Avatar
that piece is the spring from the radio door,you will need it back in.
that ground spot is not gonna be good at all,mount ground to floor ,drill a small hole and use a good screw and mount it to the body securely.
Old Mar 3, 2009 | 01:58 AM
dundeal67's Avatar
I know it fell from the radio door, but I can't figure out how to put it back in. Is there a picture of where it belongs and how it goes in?
Also is there another place where I can attach the ground to? I don't want to drill any holes into the car and I don't have a drill anyways so that would be hard to do.
Old Mar 4, 2009 | 06:18 PM
dundeal67's Avatar
bump....any ideas regarding if the amp has sufficient airflow and how to increase it? Also a better place to ground the amp without having to drill hole (use an existing screw)??
Old Mar 4, 2009 | 07:36 PM
GQQSE13's Avatar
^^ i just drilled a hold by where the spare wheel area is, grinded off the paint that was there and it grounded just fine.
Old Mar 4, 2009 | 07:58 PM
dundeal67's Avatar
I would do that, but I don't have a drill, thats why for simplicity sake I would rather use an existing screw .
Old Mar 4, 2009 | 08:27 PM
GQQSE13's Avatar
oh ok sorry. i dunno then. that's why i did that as i couldn't find another good one back there
Old Mar 4, 2009 | 09:26 PM
Joyride's Avatar
Thats a ____y a ground. You can use that bolt but run the wire under everything. The wire has to touch the bare frame. I used the middle of those bolts. But first i used a dremel to sand away any paint then i mounted the ground.
Old Mar 6, 2009 | 09:42 PM
dundeal67's Avatar
Thanks Joyride, I'll probably try that.
I'm still worried about the airflow of the amp though. I often travel between the norcal and socal, which is about 450+ miles. Would the amp get too hot since its underneath the carpet? Or is it fine where it is?
SuBSiN
Mar 13, 2015 04:02 AM
randomsuper
Feb 27, 2015 01:29 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
