Modifying bracket so that CD cover closes
Old Mar 3, 2009 | 01:21 AM
matt503x's Avatar
Default Modifying bracket so that CD cover closes
I just had a DDX512 installed, but my CD cover won't close. It gets caught on the top of the new deck. I was wondering if anyone had a way that I can fix this?
Thanks
MV
Old Mar 3, 2009 | 01:37 AM
ack154's Avatar
Well I know that on the AVICs, you can drill out different holes in the OEM brackets and the deck sits back a tiny bit farther to let the door close.
Old Mar 3, 2009 | 02:05 AM
KrazyAznScion's Avatar
its not that hard man, just measure/guess how much you wanna set back, mark em on the brackets and drill away, i did that for my dual XDVD8265 double din.. no biggie, have fun
Old Mar 3, 2009 | 02:08 AM
dave2610's Avatar
if it uses the oem bracket do like ack154 says theres even little indents where u should drill
Old Mar 3, 2009 | 02:25 AM
matt503x's Avatar
I didn't install it though .... Does anyone have a picture walk through of how to take apart the main console so I can take out the deck?
Old Mar 3, 2009 | 02:32 AM
its goin to take some muscle, but start pullin the shifter console from the bottom (oh the sides where the silver trim ends), then just pull the main console (the one with the door) from the top and it should all come out, now you can see the unit, the unit is supported by two bolts up top and two screws on the bottom of the bracket... from there you know what to do once you get it out..
Old Mar 3, 2009 | 02:39 AM
dave2610's Avatar
heres a d3 install
https://www.scionlife.com/forums/viewtopic.php?t=165675
Old Mar 10, 2009 | 07:08 AM
ScionHI's Avatar
Yea, like what was said earlier, the 4 "indents" on the stock bracket need to be drilled in so it will sit flush with the receiver since you're moving it back around half an inch. Then just refit, and do a guess and check if any more drilling needs to be done, but it wasn't necessary on my Pioneer AVH-P4000 install. Good luck .
Old Mar 10, 2009 | 10:40 PM
yellowxhoodie's Avatar
that^
and take the waterfall off and use a dremel to file away some of the plastic on the backside.
Old Mar 11, 2009 | 03:35 PM
trrocks03's Avatar
that^
This is what I did with my f90bt, and it works fine. It was kinda tight prior to cutting out some of the plastic, but now it fits great. It is so close that I can push the outside of the door (when its closed) and it will push the **** in (I can tell cause it beeps at me).
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
mischadoll
Mar 9, 2015 05:48 AM
kahsperr
Regional - Pacific South
Jan 3, 2015 04:26 AM
hampton1100
Jan 2, 2015 08:13 PM
ScionLife Editor
Nov 20, 2014 05:20 PM
