Zpi S-pipe question
Old Mar 5, 2009 | 12:34 AM
SlimJim07's Avatar
Default Zpi S-pipe question
i recently bought a used zpi s-pipe from a member and when the tech was installing it he said that the bolts i had wouldnt work..i have a megan racing header and i was wondering if anybody else had this problem and what size bolts i needed
Old Mar 5, 2009 | 09:03 PM
SlimJim07's Avatar
anyone????? i searched and found nothing and i want to put it on asap.
Old Mar 5, 2009 | 09:10 PM
AcidDrop's Avatar
yes that is how it is, used to have a zpi s-pipe but changed to a megan s-pipe after.
you will need a flange for the part where to connects to the midpipe so it won't leak and for the bolts to the header you will have to buy new bolts which will of course be a different thread and just bolt them on. if you ever plan on switching back to a stock or other brand s-pipe then just rethread the hold with a 1/8 and it'll be good as new.
Old Mar 6, 2009 | 01:43 AM
SlimJim07's Avatar
do you know the exact size bolts you used?
Old Mar 6, 2009 | 03:18 AM
AcidDrop's Avatar
same lenght as the stock bolts, i think they are like 6 inches and get washers for them too.
Old Mar 6, 2009 | 01:24 PM
SlimJim07's Avatar
well if its the same length as stock how is it gonna work
Old Mar 6, 2009 | 06:08 PM
AcidDrop's Avatar
because if you look at the bolt, there is the thread and after that the bolt gets bigger and that is where it stops because that is how they made it for stock parts, you need to buy a bolt that just has a thread all the way to the top. hopefully you understand what i mean, if not then i'll try my best to take a pic of the bolts to better explain it to you.
Old Mar 6, 2009 | 08:41 PM
SlimJim07's Avatar
the tech said i need longer ones
Old Mar 14, 2009 | 07:34 PM
SlimJim07's Avatar
pictures would definatly help
Old Mar 16, 2009 | 04:22 AM
AcidDrop's Avatar
been away for a few days due to HIN but i'll try my best to take pics tomorrow afternoon to show you what i mean.
Old Mar 16, 2009 | 02:04 PM
Schuller's Avatar
I had a Megan header and ZPI spipe and simply used some new nuts and bolts to bolt it together. It does not get any simpler than doing what you are trying to do. Get a jack, some stands, adjustable wrench and a $25.00 socket set. Hope this helps.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
