IDLE A/F ratio 10.0 please help
Old Mar 9, 2009 | 04:07 AM
bridfi's Avatar
Default IDLE A/F ratio 10.0 please help
alright, after all my other problems, i finally got my car together and running, took it home today. i let the ecu kind of get used to the new engine by cruising at about 55-60 mph for a while, now it idles filthy rich 10.0 or less, my gauge doesnt read any less.
and when im cruising, in boost, out of boost, full throttle, half throttle, it is off the gauge (over 17)
i tried disconnecting my maf, primary o2, separately and both together, it didnt help things either way, it was either too rich or too lean. i have to drive this car for a week, i cannot get it retuned anytime soon, and i dont think that is the problem, can anyone help me? pleasE!
Old Mar 9, 2009 | 04:09 AM
bridfi's Avatar
also have 10 codes, 3 worry me:
P0172 - System Too Rich
P0500 - Vehicle Speed Sensor Malfunction
P2196 - Rich Condition
Old Mar 9, 2009 | 04:53 AM
thendawg's Avatar
over 17 under boost and under 10 on idel? sounds like maybe a bad wideband sensor. I couldnt see a shop letting a car leave tuned like this
Old Mar 9, 2009 | 04:57 AM
bridfi's Avatar
what shop? there is no shop..
its not a bad wideband, it idles like ____ and is throwing codes for system too rich, and it wants to die, even at full throttle it bogs like crazy
Old Mar 9, 2009 | 04:23 PM
BlackKnight's Avatar
Music City Scions
Detailed specs on engine/mods/ecu or piggyback
Old Mar 9, 2009 | 04:27 PM
CarbonXe's Avatar
Just curious, but why the ____ would you go WOT when the car is running like crap? You're just asking for even more problems.
Old Mar 9, 2009 | 05:58 PM
bridfi's Avatar
Originally Posted by CarbonXe
Just curious, but why the flip would you go WOT when the car is running like crap? You're just asking for even more problems.
at WOT, the car runs fine, a/f r is at about 12.8-13, every other situation it is either too lean or too rich. this car ONLY wants to run at WOT.
Old Mar 9, 2009 | 05:59 PM
CarbonXe's Avatar
So why did you say it was running lean at WOT?
Old Mar 9, 2009 | 06:01 PM
bridfi's Avatar
engine - factory 2008 xB 2.4L
mods - TRD s/c w/NST 9.5 psi pulley, header, exhaust, intake
ecu - 2005 tc TRD reflashed ecu
no piggyback
im thinking i need to get it retuned, but i dont think its just that. would the small differences with the engine make that much of a difference with the AFRs?
Old Mar 9, 2009 | 06:02 PM
bridfi's Avatar
full throttle out of boost runs lean (17+)
full throttle in boost = 13
Old Mar 9, 2009 | 06:04 PM
CarbonXe's Avatar
mods - TRD s/c
There is your problem.
Old Mar 9, 2009 | 06:05 PM
Ace83's Avatar
Ronin Scion
im a lil confused here.. but again what setup do you have? no vacuum leaks or exhaust leaks?
Music City Scions
What injectors are you using? That is lean under boost you do not want high 12's you need low 12's and high 11's. Cruise should be around 14-15 AFR not 17.
Old Mar 9, 2009 | 06:13 PM
bridfi's Avatar
no exhaust or vacuum leaks from what i can see
Old Mar 9, 2009 | 06:40 PM
thendawg's Avatar
Yea 13's under boost = car go boom - i thought you had it tuned by a shop due to the phrase " i cannot get it retuned anytime soon" sorry - so yea 05 ecu with 08 motor - never tried that but doesnt sound like a great idea - 08 motor is higher compression than 05 so i would venture to guess the base fuel/ign tune would be diff. Also what intake ar eu using? If its too large it can cause it to run lean.
Old Mar 9, 2009 | 06:41 PM
Ace83's Avatar
Ronin Scion
i assume its just a tuning issue.. get that thing tuned and you should be fine
Old Mar 9, 2009 | 07:30 PM
bridfi's Avatar
getting it retuned this weekend hopefully
Old Mar 9, 2009 | 07:31 PM
bridfi's Avatar
its a custom 2.5" intake
Old Mar 9, 2009 | 07:41 PM
ElevationTC's Avatar
Thats your problem... OUR MAF HAS TO BE IN A 2.75 pipe
Old Mar 9, 2009 | 07:44 PM
Ace83's Avatar
Ronin Scion
^^ are you 100% about that? i thought stock maf housing is 2.5 pipe? but i doubt that the problem he has though, he has major fueling issues not just sections of it.. im sure its the tune
