dash lights check engine esc traction control all on
Old Mar 21, 2009 | 12:18 AM
buzzking's Avatar
Default dash lights check engine esc traction control all on
All my dash lights keep lighting up. Last week was "fixed" under warranty at Toyota. Lighting up again today. Engine sputters and stalls. Taking back to Toyota tomorrow. Anyone else know of this issue?
Old Mar 21, 2009 | 03:24 PM
Amoxaphobic's Avatar
That could be a lot of things actually.
But please let us know what the dealership says.
Old Mar 21, 2009 | 05:36 PM
Enocalypse's Avatar
I have seen this before on a srt4 forum. Some where your wire harness is getting pinched. In the case of the srt4 the engine some how moved and pinched the harness. They had to replace the whole harness.
Old Mar 21, 2009 | 05:39 PM
coryjames's Avatar
go to a auto part store the will do a free check engine light scan tell me the codes i can help i have thrown every code under the sun my car being turboed let me know ill help out and the vsc and traction come on when the check engine comes on
Old Mar 22, 2009 | 01:15 AM
BFDBOX's Avatar
It will only display generic codes, there scanners are not that great. If hes having that many problems he needs to take it back to the dealer. Even if he does get the codes from lets say auto zone scanner. It will not be good enough for him to diagnose the problem. Engine sputtering and stalling, to many problems could cause that. Something as simple from a common shared ground on the sensors to who knows what...Step by step they'll brake it down and find the problem.
Just take it back to the dealer man, if it was warranty work anyway the have to fix it.
Old Mar 22, 2009 | 02:45 AM
masterbB's Avatar
what have you modified?
Old Mar 22, 2009 | 04:21 AM
coryjames's Avatar
true on that i was just trying to help him out if it was something easy
Old Mar 22, 2009 | 04:58 PM
buzzking's Avatar
I have no modifications. The wiring harness was replaced last time. Toyota said that was the problem. It was obviously not the culprit. Since I still have the same problem.
Old Mar 22, 2009 | 11:04 PM
BFDBOX's Avatar
Ouch, my sisters 07 corolla had a similar problem to this. It was actually a bad computer that they started recalling. Becareful some dealer dont always know how to diagnose electronics and will just throw parts at the car. It might be the simple stuff they over look, best of luck man.
Old Apr 19, 2009 | 03:15 AM
mnscionxb's Avatar
gas cap on tight?
Old May 4, 2009 | 05:45 PM
scion_tiger08's Avatar
Default All lights coming on at same time?
I have had this same issue, and what the issue were my brakes where down to 2% pad left on them! Now this may not be what is going on with yours, but then it’s an ABS issue! I would bring it in as soon as possible!
Old May 4, 2009 | 06:15 PM
mnscionxb's Avatar
I run my pads down to metal and no lights
Old May 4, 2009 | 06:18 PM
Default Lights
Well this is what the dealer told me the reason for the lights! All I know is that it was snowing the two times that the lights came one and the ABS was out and then came back on and the light went off!
Old May 4, 2009 | 06:54 PM
Zsanz's Avatar
no mean to thread jack but while on topic...
got the maint reqd light on at 33500 anybody know how to turn it off so i dont have togo to the stealership
Old May 4, 2009 | 06:59 PM
Default Service light
This is an easy one. Hold down the mileage reset **** on the trip gauge while turning the key to the power position. You do not need to turn the car over, but hold it for ten seconds or until the light goes away! This works on the xB1 and xB2. You just have two ***** on the xB2. The one on the left is to change the options on the first gauge and the second is for the trip gauge.
Old May 5, 2009 | 01:12 AM
Zsanz's Avatar
thank you kind sir.
Old May 5, 2009 | 01:19 AM
CIONIDE's Avatar
Your trip counter should be on "Trip A" when you do this. When you turn the key to "On" while holding the trip reset button, 5 dashes will show up and go out one at a time. When they're all out, you're done.
Old May 5, 2009 | 04:56 AM
Zsanz's Avatar
cionide ftw
thanks man.
sorry bout the thread jac hope it all works out
Old May 5, 2009 | 01:04 PM
coryjames's Avatar
so what was the problem
Old May 8, 2009 | 01:03 AM
Beckenbauer's Avatar
Music City Scions
not to thread jack either so cionide if i have the VSC off, trac, and Check engine light on and I turn the key to "on" and trip computer on "trip A" and hold the trip reset button the lights will stay on and then go off? just wanted to make sure i had that right.
