dash lights check engine esc traction control all on
All my dash lights keep lighting up. Last week was "fixed" under warranty at Toyota. Lighting up again today. Engine sputters and stalls. Taking back to Toyota tomorrow. Anyone else know of this issue?
go to a auto part store the will do a free check engine light scan tell me the codes i can help i have thrown every code under the sun my car being turboed let me know ill help out and the vsc and traction come on when the check engine comes on
Just take it back to the dealer man, if it was warranty work anyway the have to fix it.
Originally Posted by buzzking
I have no modifications. The wiring harness was replaced last time. Toyota said that was the problem. It was obviously not the culprit. Since I still have the same problem.
I have had this same issue, and what the issue were my brakes where down to 2% pad left on them! Now this may not be what is going on with yours, but then it’s an ABS issue! I would bring it in as soon as possible!
Well this is what the dealer told me the reason for the lights! All I know is that it was snowing the two times that the lights came one and the ABS was out and then came back on and the light went off!
This is an easy one. Hold down the mileage reset **** on the trip gauge while turning the key to the power position. You do not need to turn the car over, but hold it for ten seconds or until the light goes away! This works on the xB1 and xB2. You just have two ***** on the xB2. The one on the left is to change the options on the first gauge and the second is for the trip gauge.
Your trip counter should be on "Trip A" when you do this. When you turn the key to "On" while holding the trip reset button, 5 dashes will show up and go out one at a time. When they're all out, you're done.
