No Powersteering Help
Old Mar 21, 2009 | 01:08 PM
streetracer99x's Avatar
Default No Powersteering Help
So i took off my power steering pulley and put a smaller belt on my car and the belt is fine but when i start it it squeaks for a bit then it doesnt after warm up so will it hurt the car if i dont have the pump on and have a smaller belt?
Old Mar 21, 2009 | 01:27 PM
Mouse's Avatar
well its hard to say how much additional stress its putting on the part...if the belt is smaller than stock...I wouldnt recommend leaving it on there. The reason it "squeaks" at start up but not afterwards is because of the rubber's natural property of expanding slightly when its warm...and contracts when cold.
Old Mar 21, 2009 | 01:37 PM
okay i didnt know its just the power steering pump is a dealer part and in my state they want 500 for only half of the part. the belt is a little slimmer meaning its a 5 rib instead of 7 but the tension pulley has pressure against it. and everything spins fine the only thing i had to do was cut the lower radiator hose to make it small enough not to hit my belt
Old Mar 21, 2009 | 01:55 PM
Mouse's Avatar
What is the original reason for taking it apart?
Old Mar 21, 2009 | 01:58 PM
my motor blew and i put a new one in but my power steering pump is cracked in half so im F*** btw do you know i can get the seal that goes on the bottom of the fuel injector?
Old Mar 21, 2009 | 02:10 PM
Mouse's Avatar
I would say that would be a question for your dealer...I've never had to replace those on either of my tC's so I dont honestly know if you can get that separate or not.
Old Mar 21, 2009 | 02:17 PM
do you think that belt will work?
Old Mar 21, 2009 | 02:28 PM
Mouse's Avatar
only if the tension is the same as stock...but again...I don't think it's very wise to run belt on a car it wasnt meant for. Generally bad things can happen using the wrong parts.
Old Mar 21, 2009 | 02:50 PM
jct's Avatar
jct
put in a manual steering rack in power steering robs you of power anyways
Old Mar 21, 2009 | 02:51 PM
right i understand that as well as a friend of mine has a tc and did the same thing in regards to that and has had no problems
Old Mar 21, 2009 | 02:52 PM
is it going to hurt my rack and pinion?
Kai99
Dec 30, 2011 10:14 AM
Redsoxx15
Jul 18, 2010 05:39 PM
TurboToyotas
Apr 18, 2009 11:19 PM
brownbanana
Sep 1, 2006 08:44 PM
Weapon-R
Scion tC 1G Aero & Exterior
59
Sep 9, 2005 11:34 AM
