wire tucking
Old Apr 1, 2009 | 05:53 PM
brownfaux's Avatar
Utah Scions
Default wire tucking
Working on this, just scouting it out before I lenghten anything. The clear rubber cap that covers some of the wires from the coil pack, it appears they are just tied off together and I can take the cap off and lenghten them. anyone see this differently than i do?
Old Apr 1, 2009 | 06:14 PM
vettereddie's Avatar
Pictures please. For the 1gen xB, we don't have a coil pack. It's a coil over spark plug design. The wiring leading into the individual coils is standard wiring. There is not much room for slack in it, i would suggest leaving the main harness alone unless you're prepared to completely rewire it.
Old Apr 1, 2009 | 06:33 PM
brownfaux's Avatar
Utah Scions
ya i am leaving the main harness alone. It's lng enough to route where I want it to go. but there are 5 wires, that look like ground wires i want to lenghten.
I'll post a pic.
Old Apr 1, 2009 | 09:13 PM
Make sure to use sealed splices in the engine bay as well. I use uninsulated splices followed by silicone sealant on the ends with shrink tubing over it. The normal pre-insulated will corrode over time and could cause headaches down the road.
Old Apr 11, 2009 | 05:14 AM
brownfaux's Avatar
Utah Scions
Keep in mind, I dont know if it starts yet.... half done.
Old Apr 11, 2009 | 05:15 AM
brownfaux's Avatar
Utah Scions
also, if yellowxhoodie sees this thread, feel free to talk crap when things break on my car, since I had to be a jackass and do it to you..... lol
Old Apr 11, 2009 | 06:57 PM
JSosa's Avatar
^^^^^ You have a HUGE mountain to climb GOOD LUCK!!!
Old Apr 12, 2009 | 05:07 AM
brownfaux's Avatar
Utah Scions
thanks. I just have the spark plugs left, then the rest is cleanup. the other harness will be done later. only about 25 of the 60 wires coming from the firewall had to be cut. the rest were moved from their original mounting points. The cutting of the 25 made it so i could untangle and re-route the others though. I was just real careful to cut only what needed to be cut,.
I'm really digging the absence of the giant loom in front of my engine now.
Old Apr 12, 2009 | 05:16 AM
chicotunner07's Avatar
engine bay already looked hot!
good luck on making it even hotter!!
Old Apr 15, 2009 | 06:07 AM
brownfaux's Avatar
Utah Scions
well, finished the last of the wires, it started up and everything is good.
tomorrow I am going to be doing the final wrap of the wires in some electrical tape, then ordering my loom to keep the wires safe from heat. I'm also going with some mesh hose covering or something dress up all the black hoses.
the two fuse boxes will be moved later, most likely they will go where the window washer fluid resivoir was.
Old Apr 19, 2009 | 05:06 PM
brownfaux's Avatar
Utah Scions
99% Done
Some random brackets...
The Merge of these wires is really giving me heartache, I cant get it perfect. I've shortened a few, and lenghtened one, just trying to get them to lay in a good circle, and not tug on the plug boots too much. Still working on it, another day or so of random poking ought to do it.
Keep in mind, the tuck of the fuse boxes is still on the back burner, that seems like ti wil make the most difference, but im really diggin the lack of the harness in front of my pretty manifold and valve cover.
Old Apr 19, 2009 | 06:14 PM
jct's Avatar
jct
so how do you like not having power brakes?
Old Apr 19, 2009 | 06:57 PM
brownfaux's Avatar
Utah Scions
so how do you like jumping to conclusions?
Old Apr 19, 2009 | 07:02 PM
coryjames's Avatar
my guess on the power brakes is he used just one solid line of hose and routed it down low out of sight am i right
Old Apr 19, 2009 | 07:19 PM
brownfaux's Avatar
Utah Scions
yes you are right!
Old Apr 19, 2009 | 07:24 PM
coryjames's Avatar
lol people man lol i dont have that nasty metal to rubber to metal back to rubber on mine either lol
Old Apr 19, 2009 | 09:25 PM
brownfaux's Avatar
Utah Scions
most of the hoses are going to be covered in a black mesh loom. i ordered the heat resistant loom today for the rest of the wires.
Old Apr 19, 2009 | 09:26 PM
brownfaux's Avatar
Utah Scions
what do you think of it though, clean without the harness in fornt?
Old Apr 19, 2009 | 09:37 PM
coryjames's Avatar
like it man
Old Apr 20, 2009 | 04:17 AM
jetblast's Avatar
That's a lottawork. Wew!!!
