Alarm LED question
Old Apr 1, 2009 | 11:36 PM
bbszero's Avatar
Default Alarm LED question
Just curious, I have some of the pre-wired superflux 4 chip LED's, and i was wondering if i could unhook the LED for my alarm and put one of these in it's place? i don't know much about alarms, is there a resistor on the LED, or is built into the alarm? So if i wired on one of mine, that has a resistor wired in already, would it work, or be super dim? Any input would be appreciated. thanks.
Old Apr 2, 2009 | 12:04 AM
spr0k3t's Avatar
The problem there is, the LED wiring required is heavily dependent on the alarm system you have. One alarm may be full on 12V (14.01V unregulated), while another may only use 3.323V. Generally, if your alarm uses a single LED indicator, it could very well be 3.3V. The easiest way to determine the voltage you need without destroying your setup: Voltmeter.
Old Apr 2, 2009 | 02:21 AM
bbszero's Avatar
Thanks for the info. I'll get a voltmeter.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
