MUFFLER VALVE WHY??? (pics)
Old Jan 12, 2005 | 12:55 PM
Stefan_TC's Avatar
Default MUFFLER VALVE WHY??? (pics)
Someone has mentioned that tC has a valve in the muffler that opens at higher rpms allowing for less backpressure (read: better flow). IS there any way to get that thing out of there compeletely? Why would I need that in my muffler at any rpms??????
Let me know,
Thanks
TOYOTA
Old Jan 12, 2005 | 01:25 PM
user 2007234908240's Avatar
I believe it is supposed to help retain low rpm torque. At higher rpms the backpressure is reduced allowing a little more flow for high end horsepower.
Of course I may be totally wrong. ;)
Old Jan 12, 2005 | 01:33 PM
Milhamscion's Avatar
I know the new Z06 Vette has one, but I never heard that about the tC :?
Old Jan 12, 2005 | 01:40 PM
SCI_TC_GUY's Avatar
yes...the tC has one......and unless you're changing the muffler....don't take it out....you'll lose low end power.....any car needs backpressure for performance...otherwise they wouldn't have put it in there...as rpm's change...obviously so does the amount of exhaust being expelled...that's why it opens more and more as your rpms rise..
Old Jan 12, 2005 | 02:31 PM
Stefan_TC's Avatar
I am not entirely convinced. I do not believe that the engine needs so much bakcpressure that it warrants a valve in the muffler. The backpressure is already there; mufflers, piping and cathalytic converter provide plenty of backpressure to the engine. So much that it makes sense to eliminate some with high quality/high flow sport exhaust we can see outher (does TRD exhuast incorporates a valve in the muffler, too??)
On the other hand, I do believe some backpressure is factored into the design of the engine/exhaust system and necessary for proper operation, I just do not believe it is so much that it warrants the valve. I would rather believe that this is Toyota's own attempt to comply with emissions/noise regulations and all these VLEV specs out there...
Anybody has any thoughts? Any words of wisdom from the tuners?
Thanks in advance...
Old Jan 12, 2005 | 03:21 PM
courier11sec's Avatar
The valve is to keep it quiet. Nothing more. THe chance of getting it out without ruining the muffler are pretty much nil.
If you want your car to be louder, just get a different muffler.
Old Jan 12, 2005 | 04:01 PM
Stefan_TC's Avatar
And why would I want the car louder???
My only concern is that the valve decreses the flow which is never good......
Is there any way to disable it so it stays open all the time?
Old Jan 12, 2005 | 04:04 PM
cad455's Avatar
the valve is wide open at WOT. you have nothing to worry about.
Old Jan 12, 2005 | 04:21 PM
Guest
Guest
Posts: n/a
ok, ok I will see if I have an extra tC muffler lieing around and cut the sucker in half. I already did it with the xA/xB Muffler and dam there were a lot of baffles, but I would like to see whats inside the tC muffler. :twisted: I will check the back stock room later today.
Old Jan 12, 2005 | 04:28 PM
jct's Avatar
jct
the A's and B's ahve 'em too so don't worry about it your not alone ;) :D
Old Jan 12, 2005 | 04:50 PM
Guest
Guest
Posts: n/a
there are no muffler valves in the xA or the xB muffler. I have physical proof of that. I actually cut an xB muffler in half to see what was inside. nothing but baffles, but no valves.
Old Jan 12, 2005 | 05:21 PM
Stefan_TC's Avatar
Stylis,
Let me know what you found and if there is any way to get thing out of there....
Thanks
Old Jan 12, 2005 | 05:25 PM
Guest
Guest
Posts: n/a
heehee, monster garage ain't got nothing on me. :twisted:
Old Jan 15, 2005 | 10:16 AM
daemonite's Avatar
yamaha first made the butterfly exhaust valve for their sport bikes. Toyota doesn't design or make their own engines anymore, it's all designed by yamaha hence why we have exhaust butterfly valves. BMW 330's have them too when you sit behind one in traffic look at the exhaust with your headlights on. You'll see it on the left or right tip.
Back pressure gives you torque, when you gas it it opens allowing free flowing exhaust gas to exit. Don't mess with it, if it was bad or served no purpose they wouldn't put it into the car.
Old Jan 15, 2005 | 11:21 AM
Stefan_TC's Avatar
deamonite,
Thanks for the info. I am not sure though that everything that the maker pust in the car is 'good'. Some of the features serve only the purpose of complying with endless regulations and limiting liability (warranty) (electronic speed limiter etc. etc)
For now I ma going to leave it as it is but I ma not going to agree with the statment that "if it is there it is needed" for the reasons stated above.
Cheers,
Old Jan 15, 2005 | 11:42 AM
Somnambulated's Avatar
Stylis... You sound like a good guy to have on the board? Where do you work at? Pardon my ignorance.
Does the valve in the tC's muffler have anything to do with the VVT-i?
Old Jan 16, 2005 | 10:02 AM
Guest
Guest
Posts: n/a
Hi Somnambulated,
I work at Precision Muffler & Brake in Milpitas,Califorrnia. AKA(The Scion Central) www.precisionmuffler.com I have yet to cut the tC muffler open, I have been very busy at teh shop, but I will crack it open on monday. Not a lot of work that day so I will have my digital camera ready. :D
Old Jan 17, 2005 | 06:38 PM
djaaronp's Avatar
geez. dyno your car. then put headers, highflow cat, 3" pipes all the way back and a valveless muffler and tell me what your low end torque does.....IT GOES DOWN. Why? you eliminated your backpressure.
its for low end torque, if you dont want low end torque, by all means, get rid of the valve.
Old Jan 17, 2005 | 07:36 PM
Stefan_TC's Avatar
Geez,
Since you seem to know the answer do you have the dyno results that support it?
Thanks,
Old Jan 18, 2005 | 04:25 AM
cad455's Avatar
the valve is open at WOT. are you worried about losing power at half throttle? i don't get it.
