weird problem when braking
Old Apr 10, 2009 | 10:16 PM
lvlonkey's Avatar
Default weird problem when braking
whenever i hit a bump while braking, the brake pedal will vibrate and i can hear a loud noise, kinda like metal hitting metal in a quick succession. the car stops fine but im wonder what could be the cause of this problem?
Old Apr 10, 2009 | 10:23 PM
Andrew1782's Avatar
Default Re: weird problem when braking
Go get your brakes checked is the only answer here.
Old Apr 10, 2009 | 10:46 PM
Hyghgynx's Avatar
When I was in a mall parking lot I didn't see a speed bump in time. I tried to brake but ended up
braking while going over the speed bump. My tC did what you described. Probably the ABS kicking
in while going over an uneven surface.
Old Apr 10, 2009 | 10:57 PM
AC's Avatar
AC
abs
weezyfbayba's Avatar
upgrade ur brakes get a BBK bcuz the tc brakes suck
Old Apr 10, 2009 | 11:23 PM
crg5990's Avatar
its the abs. i get it alittle everyday when i leave school. no big deal
Old Apr 11, 2009 | 03:49 AM
lvlonkey's Avatar
is the abs supposed to do that every time im braking while go over a bump? seems pretty disconcerting.
Old Apr 11, 2009 | 04:46 AM
xzsimmnzx's Avatar
all ABS systems work the same the vibration in the pedal is normal
Old Apr 11, 2009 | 05:31 AM
crg5990's Avatar
mine does yea. but if your really worried about it just bring it somewhere and have a tech sit in or something while you drive around.
Old Apr 11, 2009 | 07:03 AM
lvlonkey's Avatar
well i understand its supposed to vibrate but is it also supposed to make that loud kinda like clanking noise?
Old Apr 11, 2009 | 07:47 AM
Mouse's Avatar
I would tend to agree with ^^ answer as the likely cause.... if you're not used to activating an ABS system on a car...it can feel and sound very strange.... I'd say you're probably okay....but if you need/want extra piece of mind...just have a local brake shop throw it on a lift and give it a quick inspection.
Old Apr 11, 2009 | 02:49 PM
lvlonkey's Avatar
haha well thanks for all the replies guys.
Old Apr 11, 2009 | 03:01 PM
rosedaleny806's Avatar
yeah its the ABS i got scared the first time i felt that over a bump and even when my car slides in the snow u feel it but its normal
Old Apr 11, 2009 | 03:08 PM
chicotunner07's Avatar
totally normal, got scared when it first happened to me, i had to get out and look around my car, lol
Old Apr 11, 2009 | 03:10 PM
lol same thing i did haha
Old Apr 11, 2009 | 03:58 PM
ScionJim23's Avatar
to be honest, I have the same issue and its not only bumps. I even get the noise when i brake and turn. sounds like a creeking metal noise. I haven't figured out what it is though. seems louder when its cold out too. my noise comes from the front of the car only.
Old Apr 11, 2009 | 04:21 PM
alltracman78's Avatar
Sounds like the ABS, the noise is the ABS actuator controlling the brake pressure, which gets to over 1,000 PSI. When you start turning that pressure on and off in the lines, it makes things jump a bit [ever hear your water pipes make noise when you turn the water off fast?].
The ABS checks the speed of each wheel while you're braking, if the speed changes between wheels the ABS actuator changes the brake pressure at the wheel[s] that are turning slower. If you're braking over bumps, in a turn [especially in sand or water], in snow, ect, it will do this.
afoulk
Dec 31, 2016 02:53 PM
Dmmcclair
Aug 13, 2015 07:14 PM
pier0723
Mar 17, 2015 03:14 AM
Slopoke21m
54
Apr 23, 2007 12:25 AM
Cameron
Dec 17, 2003 07:27 PM
