My tC's suspension
Old Apr 21, 2009 | 10:27 PM
TechtC's Avatar
Default My tC's suspension
Ok. You gals/guys on here seem to know your ish so Im asking this:
I have a 07 tC. About two years ago I dropped it on some TEIN S Techs. Upgraded to 18's and have had it aligned and so forth when I should. But over the past few months the camber has seemed WAY off. I can feel the inside of the tires are wearing but not that much. Anyway, while parked on a flat surface I noticed that the drivers side rear is sunk WAY WAY more than any other wheel. When I measured the ride hight I am 9 inches from bottom of bumper to ground on passenger side and Im a HOLE INCH AND A HALF LOWER on the drivers. I really dont know suspension, just engine. SO If anyone can throw out any ideas I can look at Id appreciate it! Thanks fellow Scion-ers!
Old Apr 21, 2009 | 10:38 PM
DonNguyen's Avatar
are you on stock struts?
Old Apr 21, 2009 | 10:39 PM
TechtC's Avatar
yupper
Old Apr 21, 2009 | 10:42 PM
ExpresScion's Avatar
Blown shock.
Old Apr 21, 2009 | 10:53 PM
ScionJim23's Avatar
bingo, blown shock most likely
Old Apr 21, 2009 | 10:55 PM
TechtC's Avatar
Great. Well, Lets say we go with the blown shock idea. how would I be able to tell with my eyes?
Big_Bird's Avatar
bingo bango, blown shock
Old Apr 21, 2009 | 11:02 PM
davedavetC's Avatar
probably sagging springs, iirc shocks wont change ride height just performance/comfort anyways
i would look at your springs, they might be sagging or worse one could have rusted and broken, its happened before wtih hotchkis springs i dont see why it wouldnt happen with otehrs.
Old Apr 21, 2009 | 11:07 PM
kuo34's Avatar
I thought only springs affected height? When my stock shocks went, I was on s-techs. The ride got incredibly harsh.
Old Apr 21, 2009 | 11:08 PM
robtheqb2003's Avatar
If its the strut, you should be able to push down on the hood and have it bounce quite a bit before stopping. If its the strut, the rebound should be different from the one that is way lower and the one that seems fine. 1.5" seems quite a bit for a blown strut though. Did you go through a tein dealer for the stechs?
Old Apr 21, 2009 | 11:10 PM
TechtC's Avatar
If it helps, the car still rides fine other than a noise from the front that I found to be the inner fender snapped and was riding the tire. Fixed that and it went away, but car still drives fine.
Brian_M1Autosport's Avatar
Banned for NON PAYMENT
need new shocks LMK maybe i can hook it up for ya
Old Apr 21, 2009 | 11:12 PM
TechtC's Avatar
Sorry Didnt say above, this is the REAR that has sunk, the REAR drivers side. I can stick 2 fingers side by side in between the tire and fender on passenger side and the tire is tucked in on the drivers. REAR that is
Old Apr 22, 2009 | 01:35 AM
davedavetC's Avatar
like i said, look at the springs, shocks dont effect ride height, only quality
Old Apr 22, 2009 | 02:42 AM
yellowxhoodie's Avatar
id def. take the tire off to make sure that the spring is still seated properly and everything looks OK.
Old Apr 22, 2009 | 03:31 AM
Just curious, did you go through ebay to get the springs?
Old Apr 22, 2009 | 03:38 AM
davedavetC's Avatar
^^ thats a good point i didnt even think of that.... if so he might have gotten the knock offs...
Old Apr 22, 2009 | 05:12 AM
alenehan's Avatar
that would suck. warranties ftw
Old Apr 22, 2009 | 06:51 AM
Amphia's Avatar
it's probably your stock struts..they're not made for afrermarket springs imo. so i would get both aftermarket struts and spring at the same time. that might solve ur problem
Old Apr 22, 2009 | 02:00 PM
NYNCTC's Avatar
take the wheel off and see if the spring is broken, as stated before, shocks dont affect ride height.
