04' 2AZ-FE out of a Camry
Old Apr 22, 2009 | 02:34 PM
Rasta's Avatar
Default 04' 2AZ-FE out of a Camry
Do you guys think this engine is too old to build. I mean its getting pistons and rods. It is the same engine that is in a TC correct?
Old Apr 22, 2009 | 02:39 PM
ahatch133's Avatar
pretty sure it is.
Old Apr 22, 2009 | 02:42 PM
Rasta's Avatar
Originally Posted by ahatch133
pretty sure it is.
too old to build?
Old Apr 22, 2009 | 02:43 PM
ahatch133's Avatar
how many miles...?
Old Apr 22, 2009 | 02:46 PM
chicotunner07's Avatar
didnt you have a sick **** blue tc? did you end up selling it?
Old Apr 22, 2009 | 02:50 PM
B_Real45's Avatar
pretty sure it is.
too old to build?
Rasta, an engine is an engine - so I assume you just want the bare block to build up?
I would get a machine shop to check the block for strength and examine the crankshaft. As long as the block, crankshaft, and main bearing caps are all in good order, you should be fine.. no matter the age.
There are Honda and Nissan guys building 15 year old motors..
Old Apr 22, 2009 | 02:53 PM
Rasta's Avatar
Yea I still have it..thats the one I am going to build.
Old Apr 22, 2009 | 02:54 PM
Rasta's Avatar
pretty sure it is.
too old to build?
Thats what I figure..as long the block is not cracked...
Old Apr 22, 2009 | 03:01 PM
Sciontistical_One's Avatar
uh, are you planning to take the motor out of the Camry and put it in the tC? I could be wrong, but in most areas you can't "legally" put a motor into a car if the motor is older than the car...
Old Apr 22, 2009 | 03:13 PM
ahatch133's Avatar
really lol?
Old Apr 22, 2009 | 03:15 PM
Dam262a's Avatar
no thats not legally here, but people seem to still do it..
Old Apr 22, 2009 | 03:18 PM
Rasta's Avatar
Are u a cop?
Old Apr 22, 2009 | 03:19 PM
Rasta's Avatar
When Im done the motor will be newer than the car I gurantee it ...:-)
Old Apr 22, 2009 | 03:35 PM
deathbyc4's Avatar
as long as its not like the early tc engines that had the bad bearings. definitely replace all the bearings.
Old Apr 22, 2009 | 03:57 PM
Are u a cop?
Nope, I just play one on TV...
Old Apr 22, 2009 | 04:10 PM
really lol?
yeah, for example, if you had a built 350 in your '69 Camaro, you couldn't exactly just swap it into your newer 1984 Firebird (or Camaro) and expect it to pass inspection for registration purposes...
but... on the other hand, you COULD take a LS1 from a newer Camaro and put it in the '69 and it would be just fine...
Old Apr 22, 2009 | 04:12 PM
equinox2355's Avatar
really lol?
That is correct. I took a few smog classes (was thinking of either running a referee station or my own smog check place). Anywho, the year of the motor needs to be the same year or newer than the year of your car. However in most cases, I don't think they would be able to tell if its an older block. There is going to be mismatched VIN numbers though on the block and the chassis though.
Old Apr 22, 2009 | 04:32 PM
Syldrin's Avatar
Wait.... so you mean to tell me ken gushi can't drive his scion tc on the streets? *gasp*
Old Apr 22, 2009 | 04:44 PM
Old Apr 22, 2009 | 05:40 PM
Rasta's Avatar
s
All bearings have to be changed..new turbo pistons and rods.
