04' 2AZ-FE out of a Camry
Originally Posted by Rasta
Originally Posted by ahatch133
pretty sure it is.
I would get a machine shop to check the block for strength and examine the crankshaft. As long as the block, crankshaft, and main bearing caps are all in good order, you should be fine.. no matter the age.
There are Honda and Nissan guys building 15 year old motors..
pretty sure it is.
uh, are you planning to take the motor out of the Camry and put it in the tC? I could be wrong, but in most areas you can't "legally" put a motor into a car if the motor is older than the car...
When Im done the motor will be newer than the car I gurantee it ...:-)
but... on the other hand, you COULD take a LS1 from a newer Camaro and put it in the '69 and it would be just fine...
Originally Posted by deathbyc4
as long as its not like the early tc engines that had the bad bearings. definitely replace all the bearings.
All bearings have to be changed..new turbo pistons and rods.
