what do u call?
Old Apr 22, 2009 | 11:55 PM
vato83's Avatar
Default what do u call?
what do u call those small fist looking things u wedge in between the coils of a spring to make them stiffer or lift it a bit
Old Apr 23, 2009 | 12:00 AM
tCtCtC's Avatar
bump stops?
Old Apr 23, 2009 | 12:03 AM
dibbz's Avatar
moose knuckles?
Old Apr 23, 2009 | 12:15 AM
vato83's Avatar
Twist In Spring & Coil Spacers/ Boosters
vato83's Avatar
thanx guys
Old Apr 23, 2009 | 12:19 AM
ScionJim23's Avatar
Cheeze wiz?
Old Apr 23, 2009 | 12:20 AM
rosedaleny806's Avatar
dom deluise?
Old Apr 23, 2009 | 07:30 PM
nodsetse's Avatar
Originally Posted by tCtCtC
bump stops?
No, bumpstops go around the shaft at the top of your struts to keep them from bottoming out.
Old Apr 23, 2009 | 08:12 PM
SquallLHeart's Avatar
arroz?
Old Apr 23, 2009 | 09:59 PM
TRDIZZLE's Avatar
washers?
Old Apr 23, 2009 | 10:45 PM
nodsetse's Avatar
For those that don't know what the OP is asking about, check this link;
http://www.autobarn.net/ac18-1601.html?site=google_base
They also make a different design made of metal.
Old Apr 24, 2009 | 01:44 AM
Mos_Def's Avatar
so lets say i want my rear to be a bit higher, would these work for that? i have never heard of these.
Old Apr 24, 2009 | 10:04 AM
mystik's Avatar
CinSity Scions
yeah, it would work for front or rear. all they do is prevent the spring from compressing as much basically raising the car a little.
Old Apr 24, 2009 | 10:44 PM
nodsetse's Avatar
Yes, that'd work, but it's not the "proper" way to fix that. The problem is, using these things can change both the effective spring rate, as well as the way the spring behaves throughout it's range of travel. They were originally made for situations where people need to carry a heavy load, with so much weight that the suspension is so compressed they have interference, like when you overload the bed in a pickup truck. They're fine for a temporary fix in that situation, but I'd strongly recommend against using them on a tC.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
BlingSlade
Oct 19, 2016 12:39 AM
kingcrux
Oct 2, 2015 12:40 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Pack34
Scion tC 1G ICE & Interior
Sep 27, 2015 07:11 PM
