Has anyone installed an MSD DIS-4 on their box?
I'm running roughly 14psi of boost
on a Greddy Turbo kit with TC injectors. My a/f ratio is in the low 11's. I wanted to install an MSD DIS-4 so that I can try to get my a/f up to around 12, and at the same time use the 2 step feature for launch control. Has anyone ever installed a DIS-4 on their box? If so, did you need to use the tach adapters? Also, I have a general idea of the which wires to splice, but would like to clarify with anyone who has done a successful install.
Originally Posted by BlueJDMBoxV2
im sure you could do it if you know what your doing or your tuner dose.
btw what motor mod's have you done if your running 14psi and have not blown.
its possible to last with easy accelleration and a light foot, slow build the pressure and don't stay there too long, but only a little longer.. watch that..
Back to your question.. I want to do this to.. except for other reasons, high compression n/a project.. the two step is the funk.. good luck!
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
