I need help with spacers and offests
Old Apr 28, 2009 | 06:23 PM
sameerpwnz's Avatar
Default I need help with spacers and offests
hi, so i bought wheels that have an offest 40mm for my XB 2004. The front ones do not fit so i need spacers. I believe i need atleast a 3mm spacers because the offest has to be below 38mm. So i was looking to get a 5mm h&r spacer, but im not sure if i need a bolt or stud. Also do i have to purchase extended wheel studs seperatly and where can i get these?
Thanks so much!
-Sameer
These are the two items i am looking to purchase, please let me know if i am on the right track.
this one is BOLT
http://cgi.ebay.com/ebaymotors/H-R-5...ht_1991wt_1593
this one is STUD
http://cgi.ebay.com/ebaymotors/H-R-5...ht_2024wt_1593
Please let me know if u can help me out it with be grealty appreciated.
Old Apr 28, 2009 | 06:47 PM
burstaneurysm's Avatar
Have you tried fitting them? et40 will fit... up to a certain width. What are the wheel specs?
Old Apr 28, 2009 | 06:53 PM
sameerpwnz's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...ht_2396wt_1593
this is the wheel
i put them on and the car would not move
Old Apr 28, 2009 | 07:50 PM
Hmm. It should fit fine. It might be hanging on the caliper, but otherwise, there's no reason it wouldn't work. With the car in the air, can you tell where it's hanging?
If it's hitting the caliper, you can probably put a 5mm spacer up front (that's as far as you can safely go without extending the studs).
Pics?
Old Apr 28, 2009 | 07:51 PM
sameerpwnz's Avatar
Yah exactly the calliper is touching. SO i need a 5mm spacer, now im not sure which one to buy. Please look at my original post.
Old Apr 29, 2009 | 03:53 AM
Get spacers with the right center bore. You're posting them for a Jetta.
http://cgi.ebay.com/ebaymotors/H-R-5MM-WHEEL-SPACER-4X100-CELICA-COROLLA-MR-S-XA-XB_W0QQitemZ180351691578QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item180351691578&_trksid=p4506.c0.m245&_trkparms=72%3A1205|65%3A12|39%3A1|240%3A1318
Old Apr 29, 2009 | 01:32 PM
swartzautoman's Avatar
why in the world did you go with a 15x7 +40,
your stock wheels are 15x6.5 +38.
#1 you should have done some reserch befor buying a set of wheels, thats what thease forums are for, get on here and look, ask questions. we will help stear you in the right direction.
in my opinion you sould get different wheels and get rid of the ones you just got, you might have to take a loss, oh well, live and learn.
go with something like a (if you want to stay with a 15) 15x8 +15 of jump up to a 16x8 +15
i bet you could sell what you have now for enough to buy another set of better wheels.
like this, this would only run you $337, and you would have no problem with thease at all
http://cgi.ebay.com/ebaymotors/15-8-...1%7C240%3A1318
Old Apr 29, 2009 | 02:14 PM
^ Well yea, that's obviously the ideal situation. But if he wants to go the spacer route, that's his deal.
Old Apr 29, 2009 | 04:53 PM
yeah i know.
im just not a fan of wheel spacers because of the problems that can happen.
in fact most mechanic shops will refuse to work on you car if you have wheel spacers installed because of the liability issues.
it 10x better in the long run to just use wheels that fits better.
now i could understand if you hade a super rare set of wheels that were a must have and you just had to make them fit............... but he just got the wrong set of wheels.
its an easy thing to fix and hes not going to loose much $ at all by just getting a different size wheel
Old Apr 29, 2009 | 05:00 PM
Spacers are fine to a certain point. People running 1.5" wheel spacers scare me, but 5mm, or even high quality spacers to a certain point aren't really that bad.
Old Apr 29, 2009 | 05:16 PM
he would loose less $ by selling the ones he has now and buying a defferent set then it will caust for the spacers.
+ the front wheels already stick out farther than the back, i think it would end up not looking right
Old Apr 29, 2009 | 05:29 PM
I totally agree with you. It would be easier to just do it right. Selling wheels can be a hassle though.
ruzzzell
Scion xB 2nd-Gen Wheel & Tire
Oct 11, 2015 04:18 PM
terrye
Sep 26, 2015 12:24 AM
axB
Sep 18, 2015 06:11 AM
reniculous1
Aug 14, 2015 03:16 PM
