question on supercharger???
Old Apr 29, 2009 | 06:18 PM
wild1413's Avatar
Default question on supercharger???
I just installed a BOV on the car!.. everything is sealed good!.. but when i took the intake manifold off from the supercharger to plug the tube that is connect to the BPV!.. i put the intake manifold back on!. now the blower (snail) is making a really loud crying noise!.. so my question wat did i do wrong? cause it never use to make that noise before!.. wat can i do to make that noise go away? i will really appreciate if u guys can help me out!..
Old Apr 29, 2009 | 06:57 PM
b52hDUNN's Avatar
are you sure its not the the bov leaking air?
Old Apr 29, 2009 | 07:10 PM
Mrsanchez925's Avatar
well if u didnt touch the SNAIL then it most likely is a leak some where... i could be wrong tho
Old Apr 29, 2009 | 08:04 PM
wild1413's Avatar
no the bov is not leaking!.. i checked it to make sure it wasnt!.. the loud crying noise is cuming from inside the snail!.. it sounds like if u were standing next to a muscle car with a supercharger!..
Old Apr 29, 2009 | 08:08 PM
maybe ur S/C just grew some nuts...?
lol jk i dunno dude... if its still under warranty take that ish to Toyota and see what they say...
well they might say its the BOV that causing it so they cant warranty it anymore. (its something they would say) lol
Old Apr 29, 2009 | 08:11 PM
wild1413's Avatar
im thinking that sumthing in side is griding inside!. the dealership well they will warranty but i got to put everything back b4 i put the bov!.. and i have to make it look like i didnt mess around with the supercharger!..
Old Apr 29, 2009 | 08:16 PM
aiy aiy aiy!
didnt u have to weld the BOV onto it?
is so i have no idea how your gonna manage that....
Old Apr 29, 2009 | 08:18 PM
wild1413's Avatar
no its not welded on there!..
Old Apr 29, 2009 | 08:19 PM
wild1413's Avatar
any one else have any clues on wat it could be???
Old Apr 30, 2009 | 02:42 AM
Windu's Avatar
My guess is you are over loading the blower. If you plugged the bypass valve you are going to burn up your blower. Centrifugal blower systems bypass a ton of air at idle and low load because they move more air than the engine is using when the throttle is closed or at low throttle position.
Old Apr 30, 2009 | 04:03 AM
wild1413's Avatar
it does sound like it is stressing!... But wat would make the noise go away!?
Old Apr 30, 2009 | 01:51 PM
gompka's Avatar
check if your bov isn't too tight, that might be the sound of compressor surge. If your bov came with springs but the smallest spring in first then move your way up.
Old Apr 30, 2009 | 09:35 PM
wild1413's Avatar
Well the bov is a piece of kaka!!!.. I'm putting the orginal bpv on and I'm a little low on oil so I'm doing an oil change!... And if that doesn't wrk going to try to warranty the supercharger!...
Old May 1, 2009 | 02:45 AM
Windu's Avatar
You have to run a bypass valve. It as a requred part of the system. Hook it back up and the noise should go away.
Old May 1, 2009 | 04:46 AM
gompka's Avatar
^ thats what he said, he said he is putting his stock bov back on. Sounds like he might have been hearing compressor surge. When my vacuum line came off my bov once it made weird sounds similar to those he described.
Old May 1, 2009 | 06:43 AM
wild1413's Avatar
ya i put the bpv back on and its still making that noise!..
Old May 1, 2009 | 09:04 AM
scikotictc232's Avatar
and this concludes why the supercharger is ____tttttt.
Old May 1, 2009 | 04:14 PM
wild1413's Avatar
Wat did u do to make the noise go away?
Old May 2, 2009 | 12:18 AM
imsonofagun's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=258639
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
