Installing windshield washer nozzels on carbon fiber hood?
Old May 16, 2009 | 04:10 PM
jamie1tc's Avatar
Default Installing windshield washer nozzels on carbon fiber hood?
Ok....I spent a solid half hour searching SOLID! I know there is a DIY on this. We know the wholes on the carbon fiber hood are to small and there is no brackets or tabs to mount the lines. I know i need to buy new nozzels to fit. What is the neatest way to mount the lines?
Old May 16, 2009 | 07:05 PM
jamie1tc's Avatar
BUMP! Nobody?
Old May 16, 2009 | 07:11 PM
MeatRocket's Avatar
im at work right now, but i can post some pics tonight when i get home.
Old May 16, 2009 | 08:47 PM
nebster's Avatar
drill a small hole then widen it open with a dremel
whats so hard about that?
Old May 16, 2009 | 08:51 PM
jamie1tc's Avatar
pics would be cool.....
Whats so hard about not being a *****!
Old May 16, 2009 | 08:59 PM
nebster's Avatar
i don't have a tc anymore, was just telling you how to do it!
Old May 16, 2009 | 11:59 PM
BZinn1's Avatar
WEll waht hood,Kami or Seibon or another......for the kami ther is no where to hang hose from really just trim them to fit tightly,you will also need to drill out a 3/4"hold where the hose go through under side of hood on the Kami and Seibon hoods so you do not pinch the line.
Seibon hood you can reuse the stock hood cloth and mount the hose behind it.probably the same with other hoods as well.
Old May 17, 2009 | 12:46 AM
jamie1tc's Avatar
yeah....another simple job turned into a 2 hour deal.......i just ask questions cause i would like to learn from others mistakes......imagine slipping and dragging a drill across your new seibon hood? OUCH...lol I got it tho. I drilled the wholes to fit the nozzles and took a small bit to open up where the tabs go. I tried to run the lines inside the hood through the wholes that were there directly under where the nozzles go. The lines kept getting kinked, so i ran them outside, and it's fine, but like you said BZ...there's no way to hang them. I think I'm gonna epoxy clips to hold them...
Old May 17, 2009 | 02:05 AM
BZinn1's Avatar
vented or oem hood,if oem with no ent install your stock hood cloth to it and it will allow you to tuck them up and cleans up the hood,we did it to my buddies seibon and it came out great.
Old May 17, 2009 | 02:40 AM
jamie1tc's Avatar
That would be sweet....it's vented VS11 I haven't put any thought into using the cloth, maybe? I'll look tomorrow if it's something i want to do. I did rip a couple of the tabs through it in a rush tho. I unbolted the oem then relized the washer lines...lol It would be a really clean look to have it on....... "considered"
Old May 18, 2009 | 11:46 PM
DonNguyen's Avatar
do you have a pic?
Old May 19, 2009 | 12:04 AM
BZinn1's Avatar
I can get a picture,my buddy importspeed on here is the one we put the cloth back on his oem Seibon,also if you ripped the holes in it a little Autozone carries the push in plugs but they are like over an inch wide instead of the small ones the hood comes with.
Also you can use it on the vented Seibon as it has the ribs in it too,you will just have to cut out the vent area.
the Kami is the hard one to do as there is no rib to drill at the vent.
Old May 20, 2009 | 01:18 AM
jamie1tc's Avatar
Wow...thanks for the info. I'll def check it out. Just drill some holes for the push pins....I'm so buzy at work i haven't had time to deal with that. I'm working on the LED's in my front lip, they went out and i'm trying to figgure that out.....lol I just need a break, I hope this weekend to put some time in, since i won't be out drinking with the crazys. I'll check it out and let ys know what happened...
Old May 20, 2009 | 05:16 AM
DonNguyen's Avatar
where do u drill the hole for the washer hose?
Old May 21, 2009 | 03:26 AM
jamie1tc's Avatar
My Seibon already has 3/4' holes directly under the washer nozzles .....
Old May 21, 2009 | 03:32 PM
DonNguyen's Avatar
pic?
Old May 22, 2009 | 01:08 AM
jamie1tc's Avatar
Don...sorry i don't have a pic yet, i'll post one tomorrow when i get a chance...
Old May 22, 2009 | 04:31 PM
DonNguyen's Avatar
ok thanks, cuz as of right now, my nozzles aren't doing anything
Old May 22, 2009 | 11:23 PM
jamie1tc's Avatar
I just got off my lazy a$$ .....I hope these help. They're just hangin now cause i hadn't had time to mess with them or put the cloth back....it came with wholes for the nozzles....
Old May 22, 2009 | 11:27 PM
jamie1tc's Avatar
I did make one whole bigger trying to get the pinched line out cause i tried to run the lines inside..... no go on that
