Scion xD Shifter Buyer's Guide
Old May 17, 2009 | 12:14 AM
ack154's Avatar
Default Scion xD Shifter Buyer's Guide
It had to happen eventually. You poor xD people are lacking in FAQs and Stickies.... so here is my first contribution. Contained here within... short shift kits, shifter bushings, and some install/product info.
[table:debaa07222]
[mrow color=red:debaa07222]Short Shift Kits
[mrow:debaa07222]Manufacturer[mcol:debaa07222]Reduction[mcol:debaa07222]Location[mcol:debaa07222]Street Price
[row:debaa07222]TRD*[col:debaa07222]30%[col:debaa07222]Engine Bay[col:debaa07222]$115.00
[row:debaa07222]NST[col:debaa07222]30%[col:debaa07222]Engine Bay[col:debaa07222]$98.00
[row:debaa07222]NST[col:debaa07222]30%[col:debaa07222]Interior[col:debaa07222]$78.00
[/table:debaa07222]
Note: TRD kit also comes with realignment plate.
[table:debaa07222]
[mrow color=red:debaa07222]Shifter Bushings
[mrow:debaa07222]Manufacturer[mcol:debaa07222]Material[mcol:debaa07222]Location[mcol:debaa07222]Street Price
[row:debaa07222]NST[col:debaa07222]Stainless[col:debaa07222]Cage[col:debaa07222]$49.50
[row:debaa07222]NST[col:debaa07222]Stainless[col:debaa07222]Cable[col:debaa07222]$29.50
[row:debaa07222]Dr Isotope*[col:debaa07222]Delrin[col:debaa07222]Cage[col:debaa07222]$27.00
[row:debaa07222]Dr Isotope*[col:debaa07222]Delrin[col:debaa07222]Cable[col:debaa07222]$27.00
[row:debaa07222]Dr Isotope*[col:debaa07222]Delrin[col:debaa07222]Cage/Cable[col:debaa07222]$42.00
[/table:debaa07222]
Note: Will confirm Dr Isotope bushings fit as soon as they arrive.
Install / Related Info:
- TRD SSK Install PDF: http://www.trdsparks.com/install/PTR46-52081inst.pdf
- NST SSK Install DIY: https://www.scionlife.com/forums/viewtopic.php?t=206836
- SSK Questions/Discussion: https://www.scionlife.com/forums/viewtopic.php?t=246114
- Shifter Bushing Install DIY: coming soon
If everything goes well with the Dr Isotope bushings, that also means that the Speed Source bushings for the tC will also fit and opens a few more doors. If you know of any other parts... please link... and I'll add them to the tables.
Old Sep 16, 2010 | 02:52 PM
two.0XD's Avatar
realignment plate, what is this used for? I mean would you need it? if not then the much better buy would be NST
Old Oct 24, 2010 | 02:52 AM
xdrajicialxd's Avatar
i got the trd quick shifter. it makes it feel so much more responsive and sporty, helps the acceleration too.
Old Oct 26, 2010 | 02:17 PM
tmrepp's Avatar
All those bushings are used at the same time?? The cage bushings are the same, no?? What about the cable bushings? What's what?
Old Oct 26, 2010 | 05:17 PM
mixD's Avatar
if you pull it all apart there are two sets of bushings if not im not mistaken there are four of them on the white plastic housing that hold the whole thing to the body of the car and more bushings that are actually hooked to the cables themselves so they are different.
Old Oct 27, 2010 | 02:37 AM
ThisorThatxD's Avatar
indeed, there is truth in his reply. personally i have ordered both the cage and cable bushings from NST (and even their SSK!). cage busings replace the factory rubber bushings holding the shift "cage" to the car. the cable bushings go into the engine bay replacing the factory rubber there. hope that clears up some muck. (if not, well im buzzed and i hope i helped someone, it took me like 10 min to get this all spelled right )
Old Aug 21, 2011 | 12:49 PM
Krait1's Avatar
what is the difference between the in cabin and engine bay NST kits? is the install on one much harder than the other?
Old Aug 21, 2011 | 01:37 PM
the engine bay one takes less time. they both shorten shifts the same amount (30% i think). i went with the in-cabin just cause i hadn't seen many who had, and cause it was a tad cheaper. took longer but am still happy with it all the same. you can install both and get even shorter throws too.
Old Aug 21, 2011 | 02:37 PM
Krait1's Avatar
Ok thanks. The engine one is out of stock on NST website, is there anywhere else it is available? no luck on ebay either.
Old Feb 21, 2012 | 05:53 AM
cubanoloko's Avatar
Plzz link where can i buy the TRD short shifter?
Old Feb 21, 2012 | 06:00 AM
cubanoloko's Avatar
And is there any problem if i buy the short shofter from TRD amd the bushings from nst?
disaster06
Dec 26, 2014 03:00 PM
carid
Dec 16, 2014 09:53 AM
disaster06
Dec 4, 2014 07:05 PM
gularti
Dec 4, 2014 01:21 PM
foxSCION
13
Dec 3, 2003 05:40 AM
