Tial 38mm Wastegate MV-S
Old May 23, 2009 | 04:06 PM
TheFantasticG's Avatar
Default Tial 38mm Wastegate MV-S
Anyone used it yet?
I need something a bit shorter than the T'netics wastegate.
- High temp NiCrFe based alloy is used for valve and 347SS valve housing will offer longer product life compared to competing designs.
- High temperature silicone Nomex reinforced actuator diaphragm.
- 17-7 PH Stainless Steel actuator spring gives consistent pressure at high temperature, resist "relaxing" at temperature to 900F (483C).
- Nitronic 60 Stainless Steel is used for the valve seat, and valve bushing.
- All Stainless Steel hardware.
- Mating weld flanges are 304L
- Color anodized aluminum actuator (Silver, Red, Blue, Purple, Black).
- 3 lower ports and two top ports for easy install, no need to rotate the actuator top at all, plugs included for unused ports.
-Ultra compact design fits in very tight spaces, the unit stands only 3.7" tall, more compact than any other external wastegate on the market today.
- V-Band inlet and outlet make install easy, flanges and clamps are in the box!
Tial Sport.com link
I found it on this site for $240
Old May 23, 2009 | 04:07 PM
Ace83's Avatar
Ronin Scion
i think elevation tc has that.. its a nice wg, i wish they have it in 44mm
Old May 23, 2009 | 04:10 PM
The one with the T'netics kit seems like it's a foot tall.
After talking with Crush, he can weld an adapter to fit the T'netics kit.
Old May 23, 2009 | 04:20 PM
Ace83's Avatar
Ronin Scion
tnetics have a deltagate flange right like the old tial 38mm? I just bought an adapter to make this fit so i dont have to weld on the manifold its gonna make it like 1-2cm taller though
Old May 23, 2009 | 04:23 PM
Compared to the old height of the T'netics wg, 2cm can be absorbed before the max allowable height I need to stay within.
Old May 23, 2009 | 05:08 PM
B_Real45's Avatar
Hey Fantastic..
Why not just have an L-shaped adapter to relocate the wastegate a little? This way you won't be spending $240 + $xx on fabing to get this Tial to work? The wastegate won't give you any better performance so that money is probably best spent elsewhere.
Old May 23, 2009 | 09:57 PM
Because I don't want to have to have my dump pipe taken off and remade/repositioned.
With this, it will mostly likely bolt up to the dump pipe... hopefully.
Old May 24, 2009 | 04:13 AM
crush02342002's Avatar
Originally Posted by B_Real45
Hey Fantastic..
i do free fab work for my boys thats why.... lol
its what ever he wants ill do
Old May 24, 2009 | 01:28 PM
Ace83's Avatar
Ronin Scion
hey how bout a cut out valve that when you open the recirc dump becomes open!
Old May 24, 2009 | 01:35 PM
ElevationTC's Avatar
Yup yup sorry guys didint even see this! Have it.. Uhh does its job!
Ive never had any problems conrolling boost! Looks hot! CFT has switched the 9 second civic to these as well
Old May 24, 2009 | 02:02 PM
it comes with two vbands and 2 v band flanges?
Old May 24, 2009 | 02:15 PM
its inlet is v band and the outlet is v-band!
Its pretty sexy!
Old May 24, 2009 | 02:31 PM
Ace83's Avatar
Ronin Scion
^^ you happen to know the size of the outlet vband? is it like 1.7"?
Old May 24, 2009 | 02:33 PM
Not sure what ever a 38mm flange would figure out to
Old May 29, 2009 | 03:41 AM
Where did you buy this adapter from?
Old May 29, 2009 | 04:16 AM
38mm is close to 1.5"
Old May 29, 2009 | 04:18 AM
Ace83's Avatar
Ronin Scion
best price i could find
http://www.frsport.com/FRS-External-...ed_p_9625.html
atpturbo and himniracing has them too.
I installed it yesterday, it works great.. I just need a new dumptube now
Old May 29, 2009 | 05:02 PM
I'm still going to need an adapter rewelded onto my dump tube or get rid of it all together.
Old May 29, 2009 | 05:05 PM
Ace83's Avatar
Ronin Scion
yeah you might need to change you dump tube anyways because of the adapter.. just dont run a dt until chris makes you one
Old May 29, 2009 | 05:07 PM
Just might have him cut it off (patch the hole) and run an open wg
