Wider tires for improved traction ?
Old May 24, 2009 | 10:45 PM
mindoculae's Avatar
Default Wider tires for improved traction ?
i am looking to buy a TC and i have two questions about handling upgrades:
1 - I'm looking at 19 inch rims but I would appreciate any help in trying to determine the widest possible tires.
Tirerack appears to package only 225s with all their 19 inch rim. Aren't wider possible ?
2 - I would like to install either TRD Shocks kit or the TRD Coil-Over kit. I can't decide
because I don't know what effect the choice will have on the question above.
Any help would be appreciated. Thanks.
Old May 24, 2009 | 10:55 PM
ack154's Avatar
1) depends entirely on the width of the wheel you're looking at
2) if you're going for something as big as 19s, i definitely wouldn't go any lower than the TRD springs - or something equivalent.
Old May 24, 2009 | 11:05 PM
mindoculae's Avatar
Thanks alot.
I am looking at the 19 inch Motegis Track Touge (225/35/19) over at Tirerack.
What number should i be looking at ?
Any recommendations ?
Thanks again.
mindoculae's Avatar
Double post. Sry.
Old May 25, 2009 | 04:06 PM
10gxiong's Avatar
what's the width on those wheels. i understand you're looking at 19's but 19x8, 19x9...?
Old May 25, 2009 | 07:33 PM
HKSpeed's Avatar
19s + wide tires + lowering = lots of rubbing.
i'd keep the width to minimum. if traction is a major concern, you shouldnt consider 19s (which are more of an appearance mod for tCs).
Old May 26, 2009 | 06:41 AM
BlkTC's Avatar
get 17x8 or 8.5 and run a 255... it's been done, do it again..
Old May 27, 2009 | 02:56 AM
mindoculae's Avatar
thanks for all the replies.
perhaps i took my concern for traction a bit far.
i really would like to keep the rims at 19 inches but finding
a decent range of options at that height is not so easy.
i'll limit the needless complications and stick with 225. thanks again.
Old May 27, 2009 | 04:06 AM
SavedByZero's Avatar
Forget getting wider tires, just get some quality 225s and not worry about it. How hard are you/could you be driving on 19s anyway.
I say stick with 17s or 18s at most if you want performance, 19s are total show rims IMHO.
Old May 27, 2009 | 04:09 AM
1989menace's Avatar
i may be thinking about this with rpf1's. any rubbing with 255 on 2 inch drop? any link? thanks
Old May 27, 2009 | 12:36 PM
queen504's Avatar
Does wider tires improve traction? Maybe I should upgrade too. My traction is horrible on these uneven roads, but it is time for new tires.
Old May 28, 2009 | 12:17 AM
Sticky tires improve traction. Wider non sticky tires don't stick better because they are wider.
evolving_machine
Oct 21, 2023 01:16 PM
powerT
11
Apr 16, 2015 02:31 AM
carid
Feb 12, 2015 11:54 AM
