Valve cover leak :/
Old May 29, 2009 | 09:18 PM
BOOSTit06's Avatar
Default Valve cover leak :/
So I have been having this problem with my valve cover leaking, I have replaced it twice and put a check valve in but still no success, I am running a zpi kit on 11lbs with a 20g turbo. Anybody else run into this problem? Help would be much appreciated.
Old May 29, 2009 | 09:42 PM
Ace83's Avatar
Ronin Scion
valve cover is leaking oil? did you change the gasket?
Old May 29, 2009 | 09:48 PM
JBT89's Avatar
did u make sure that valve cover gasket wasnt mis aligned b4 u closed it offf
Old May 29, 2009 | 09:50 PM
TheFantasticG's Avatar
Has the engine over heated before?
Old May 29, 2009 | 10:15 PM
BOOSTit06's Avatar
No the engine has never overheated, it is a very small leak, The gasket has been properly installed, Im just not sure :/
Old May 29, 2009 | 10:49 PM
Ace83's Avatar
Ronin Scion
do you have a new gasket or reused it?
Old May 30, 2009 | 12:25 AM
BOOSTit06's Avatar
no it is a new gasket, I looked at it closer tonight and I think there might be a hairline crack in it :/
tckid21
Mar 12, 2017 09:16 PM
smnHI
May 14, 2015 08:49 PM
SeT
Apr 1, 2015 07:39 PM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
peppy
15
Mar 24, 2004 10:48 PM
