Boost Creep possible solutions
Unexpensive solutions please. I heard,"get a new turbo manifold" but that will have me change all the piping and customize things. I heard,"get a boost controller" but this only helps to limit the creep. It doesnt fix it. Any suggestions?
go back to stock....boost creep is almost inevitable....a new manifold will fix it and so will a boost controller.....on the boost controller you can just have it cut boost at 8psi
lol Well thats one idea. But i dont think ill be able to go back to stock. Im running a turbonetics kit and from what i hear its exhaust manifold was designed incorrectly for the wastegate. Its not allowing it to work properly. Getting a larger wastegate might work but i dont want to spend money for something that might work. Any ideas?
i would see if they have an updated exhaust manifold if not i would get a different manifold.......i mean you can just tell your tuner it tune it to whatever psi your creeping to and just go with that.
Originally Posted by Mrsanchez925
Not to thread jack but j/w cuz when im in 5th and i WOT it goes up to 11-13psi then levels back out to 10psi (which i am tuned at) within a couple of seconds..
is that what boost creep is??
^^ speaking of wastegate, the 44mm i bought from you worked amazing!!! no boost creeep and very consistent, i actually have to up the wastegate crack pressure on my controller to make spool more faster.. but then my axle broke on 4th run!!
Like I said a good built manifold and properly sized wastegate for turbo and exhaust flow.
There's nothing wrong with his wastegate / manifold setup. Get a boost controller.
My boost is rock solid at 10psi and I have a boost controller. Full boost at 3200 rpm on a conservative tune to redline.
If other exact setup is not creeping then it might not be the manifold or wg.. as for me, the wastegate size was the issue on my setup since boost im running is low a bit low for turbo i have
haha nothing to be proud off.. kept stalling but its like 16s.. RT is like 2.22* trap is around 94-95 lmao, oncee the car moves the tires spins lmao.. I dont feel bad though, my bud's mildly modded nizmo 350z have pretty much same numbers
Originally Posted by crush02342002
so ace whats the track numbers looking like?
little more practice and a little tuning youll be running 14s if not 13s. rt is pretty slow...lol...doesnt really sound like you were really launching it. i think my first time at the track was pretty similer so dont worry about it. I think your stock axle was prolly already on its way out though.
