Wheel Spacers to flush out Factory Rims?
Old May 30, 2009 | 03:55 PM
XionLion's Avatar
Default Wheel Spacers to flush out Factory Rims?
Looking for wheel spacers that would or will flush out my factory rims. I also have a 2 inch drop on it.
Will I be capable of getting a spacer set that will allow me to keep my suspension travel?
__________________
Old May 30, 2009 | 04:46 PM
ack154's Avatar
If you try to go flush with a 2" drop, you will likely get some rubbing.
Typically to get flush you'd need something like 15mm in the front and 20mm in the rear.
Old May 30, 2009 | 05:28 PM
yellowxhoodie's Avatar
yea, your gonna need stretched tires and/or camber.
Old May 30, 2009 | 05:35 PM
o8tC's Avatar
just get new wheels.
Old May 30, 2009 | 08:50 PM
Yanki01's Avatar
i just grabbed a set of the stock wheels and tires, whats the offset on them? what about 15mm front and rear? i might want this but dont want flush, im on hotchkis springs but thinking of getting coilovers to raise the rear a bit?
Old May 30, 2009 | 09:22 PM
o8tC's Avatar
i think they're 17x7 et/45
Old May 30, 2009 | 09:29 PM
Ro_Ja's Avatar
I just put 25mm spacers on my friend's car about a month ago and he was almost flush. You'll need to be around +10 or lower to be flush.
Old May 30, 2009 | 09:41 PM
o8tC's Avatar
pics?
Old May 31, 2009 | 10:42 PM
Yanki01's Avatar
i was checking out the Ichiba wheel spacers and it looks pretty easy if im looking at it right? remove the wheels, put the spacer on, bolt wheels back on? is it really that easy, no removing the caliper or anything like that? here's from Ichiba web site. Is it the same for the H&R spacers?
is there pros and cons of going that route?
Old Jun 1, 2009 | 02:52 AM
Ro_Ja's Avatar
^^ That's the style spacer I installed on my friend's tC. If you go over 5mm, your bearings will hate you.
Sorry, o8tC, no pics.
Old Jun 1, 2009 | 02:57 AM
Yanki01's Avatar
why so?
Old Jun 1, 2009 | 03:01 AM
SoleLaced's Avatar
supposedly, it addeds crazy amounts of stress on the bearing since its rotational weight is offsetted so much farther.
am i right?
Ro_Ja's Avatar
The larger spacer you go on stock bolts, the more stress you place on them. Enough stress over time will cause damage.
Old Jun 1, 2009 | 03:07 AM
Yanki01's Avatar
so the better alternative is to get longer bolts? if i do this, then ill be removing the caliper and rotor correct?
http://www.ichibausa.com/toyota.html
Old Jun 1, 2009 | 03:08 AM
Yanki01's Avatar
i plan on putting spacers to run my newly purchased stock wheels and tires. im thinking 20mm front & 15mm back? not 100% sure yet?
Old Jun 1, 2009 | 03:10 AM
SoleLaced's Avatar
Best thing to do, run wheels that fit what youre looking for.
Spacers are a cheap alternative that can have expensive repercussions.
Old Jun 1, 2009 | 03:12 AM
Ro_Ja's Avatar
Yeah, pretty sure.
Old Jun 1, 2009 | 03:20 AM
Yanki01's Avatar
unless done right by getting longer bolts correct? as of right now i dont plan on purchasing another set of wheels because the ones i want aren't cheap and discontinued. I just want to be sure if i get the longer bolts ill be OK with running the spacers i want?
Old Jun 1, 2009 | 03:58 AM
Yanki01's Avatar
it looks like Ichiba version II is the one i should be going for. Its made so we dont have to replace the stock bolts with longer ones. it looks like it will be easier after all. cant wait, now its decided on what size? 15mm front and 10mm rears on hotchkis springs?
Old Jun 5, 2009 | 01:42 AM
highvoltage1's Avatar
Version one comes with longer studs just FYI if its longer than 5mm. The version II are nice but i would go with version one because the bolts are made longer and specifically for the spacer. version II still utilizes your stock bolts which i wouldn't recommend.
