Wheel Spacers to flush out Factory Rims?
Looking for wheel spacers that would or will flush out my factory rims. I also have a 2 inch drop on it.
Will I be capable of getting a spacer set that will allow me to keep my suspension travel?
__________________
__________________
i just grabbed a set of the stock wheels and tires, whats the offset on them? what about 15mm front and rear? i might want this but dont want flush, im on hotchkis springs but thinking of getting coilovers to raise the rear a bit?
i was checking out the Ichiba wheel spacers and it looks pretty easy if im looking at it right? remove the wheels, put the spacer on, bolt wheels back on? is it really that easy, no removing the caliper or anything like that? here's from Ichiba web site. Is it the same for the H&R spacers?
is there pros and cons of going that route?
so the better alternative is to get longer bolts? if i do this, then ill be removing the caliper and rotor correct?
http://www.ichibausa.com/toyota.html
Originally Posted by SoleLaced
Best thing to do, run wheels that fit what youre looking for.
Spacers are a cheap alternative that can have expensive repercussions.
it looks like Ichiba version II is the one i should be going for. Its made so we dont have to replace the stock bolts with longer ones. it looks like it will be easier after all. cant wait, now its decided on what size? 15mm front and 10mm rears on hotchkis springs?
Version one comes with longer studs just FYI if its longer than 5mm. The version II are nice but i would go with version one because the bolts are made longer and specifically for the spacer. version II still utilizes your stock bolts which i wouldn't recommend.
