allignment problem?
Old Jan 18, 2005 | 10:24 PM
scionmotiondotcom's Avatar
Default allignment problem?
not sure if this is weather related, but lately been noticing the car seems to be slightly drifting toward the right. the steering wheel is not really loose and seems to be a little bit to the right. it is very cold and snowy here and i know i have hit some potholes, is it possible my allignment has gotten messed up? what else should i look for? and is this something covered by the warranty?
Old Jan 19, 2005 | 01:35 AM
toyota_scion_tc's Avatar
Alignment is covered until 20,000 miles if that is your problem. Keep in mind most roads have crowns in them. How hard is it pulling?
Old Jan 19, 2005 | 01:39 AM
not too bad now but seems like it shouldnt be doing that
Old Jan 19, 2005 | 02:31 AM
toby3002's Avatar
my car seemed to be doin the same thing when i first got it, but now i dont really notice it that much. either i got used to it or it fixed itself, but i was too lazy to take it to the dealer.
Old Jan 19, 2005 | 04:17 AM
sciontc_mich's Avatar
yeah take it to the dealership and have them check the alignment.. chances are it's probably out.. i've noticed this suspension is extremely sensitive to adjustment.. it probably is out a little.. just make sure if they do an alignment they center the steering wheel
Old Jan 19, 2005 | 07:14 PM
inkprincess's Avatar
This is common on a lot of newer model veh. There's something called torque steering, and it sometimes causes a slight drift to the right. This is normal...it's just the steering compensating for the torque pressure. I believe if you look, this is also stated in the owner's manual. Also, if you've already had an alignment, the second one will not be covered under warranty. Toyota_Scion_TC is right. For 1999 and later years, the alignment/balancing warranty states that it is only applicable within the first 12 months or 20,000 miles. So if the pulling is extreme to you, take it to the dealer and have them do the alignment.
Old Jan 19, 2005 | 07:16 PM
Old Jan 19, 2005 | 11:12 PM
iowagary's Avatar
So our car is covered for alignment once in the first year/20k miles? I'll make sure to use that if it's the case. I think my alignment is ok now, but I'll definitely want to get it aligned after this winter.
Old Jan 19, 2005 | 11:28 PM
rhymeswithorange's Avatar
yup, i've had the same issue - only mine pulls to the left and the steering wheel is DEFINITELY off center... but once again i am too lazy to take it to the dealer also, haha! it's bad enough though that i want it looked at, problem is in about 1 month i've putting lowering springs in, and i know they won't cover alignment AFTER i do that, so i guess i'm kinda screwed cuz if they align it now and fix the problem but then it gets worked after the lowering springs i'd have to go through the process again. whatever.
Old Jan 19, 2005 | 11:48 PM
pdrizzle's Avatar
DeepSouth Scions
Before you give up hope, read this:
its from maxima.org (since im a previous maxima owner)
"Under the Magnusson-Moss Act, aftermarket equipment that improves performance does not void a vehicle manufacturer's original warranty, unless that warranty clearly states the addition of aftermarket equipment automatically voids the warranty or that the aftermarket device is the direct cause of the failure. The easiest way to check this is to look in your owner's manual under "What is not covered." Nonetheless, Dealers receive less compensation for warranty work than regular service rates and some have tried to deny warranty service. Under Magnusson-Moss Act a dealer must prove, not just vocalize, that aftermarket equipment caused the need for repairs before they can deny warranty coverage. If they cannot prove such claim-or proffer a questionable explanation- it is your legal right to demand compliance with the warranty. The Federal Trade Commission (202-326-312 administers the Magnusson-Moss Act and monitors compliance with warranty law."
Read this for more information: http://www.usdieselparts.com/mmwa.cfm
This is federal law. Don't let any dealer try to tell you different, if they do, go to another one or call Scion USA and get them to give the service manager a little call too.
So, the burden of proof is on them to prove that your mods caused the alignment to become out of whack. We all know that lowering a vehicle or swapping out suspension parts does affect the way the vehicle is calibrated, but it's worth a shot. Get as much free as you can!
Old Jan 20, 2005 | 12:15 AM
i like that, so simply put i call tell my sales guy, hey i'm having alignment issues - then put in the springs - then go in to get alignment fixed! haha. i'll even get a receipt from the guy i know putting in the springs so i can properly argue the date and everything.
Old Jan 20, 2005 | 04:50 AM
DL_tC's Avatar
my allignment is a little off. nothing big. but when i center the steering wheel, the car will head leftward.
when i went in to get my oil change, i told the service person that the allignment is a bit off. it might be due to winter tire/wheel package i swaped on, but i doubt it. he told me that i get one free allignment, and if i used it then, i wouldnt be able to get a free one later on. since it was minor, and since i plan to put in the trd lowering springs i got in the spring (through a friend, not a shop or dealership), i decided to just wait. i asked him if i got the trd lowering springs installed by myself, whether or not i would be able to get the free allignment. he said yes. so im guessing that he was just saying that he would hook me up? i hope thats true...
anyone know how long you should let the springs settle before getting an allignment? or should i just get it right after installation?
Old Jan 20, 2005 | 05:18 AM
Jammet's Avatar
Not true. I have had the same pull towrds the right. The manufacture has a certain system error variance of allignment to meet. The difference may be small, yet is still noticible. I've taken mine in the first time because of the allignment and a second time because I still noticed the pull. They crossed my tires the second time, in order to determine whether it is specificly an allignment issue or something more such as the compression. Now my steering pulls slightly to the left, but not as noticibly as it did to the right. Yes, some of this may be due to the crown in the roads, but not as much as the allignment was affected.
Anyways, it does not cost anything to get the allignment checked a second time as long as you still notice the same problematic issue.
To make sure your allignment is not correct, try driving on the interstate once going each direction(to ensure its not due to the wind). And if possible strattle the center of the road and see how she pulls.
Old Jan 21, 2005 | 11:20 AM
thebends1's Avatar
I just got my tc a week ago and I too have noticed a slight pull to the right as well. My tc is just stock from the factory and nothing has been added to it, so thats ruled out.
Old Jan 21, 2005 | 11:29 AM
Somnambulated's Avatar
I was wondering about this...
My tC is about a two months old now. I noticed the slight pull to the right when braking, and always assumed it was just the contour of the road.
I noticed that very rough patches in the road sometimes 'steer' the car to the side a little--not enough to be a problem, but there is a definate 'tug'.
I'll probably have them align it when I get my oil changed, and I'll post if anything changes.
RY_TC07
Jul 18, 2017 05:18 PM
bravosixniner
May 24, 2015 09:56 AM
ScionXa06
May 18, 2015 10:05 PM
claiknx
May 17, 2015 11:44 PM
Moth
Apr 14, 2015 12:17 AM
