what did you use to remove the HVAC LCD?
Old Jun 7, 2009 | 12:01 AM
skinnayyy's Avatar
Team Scionara
Default what did you use to remove the HVAC LCD?
soooo i've done everything with my gauges and HVAC other than the LCD on the HVAC and i want to know how to get it off? yes i have read every DIY and it says to use a desoldering braid... and i have one... but it's separate from the iron... kinda like a little snot sucker for babies.. just for solder. Is one that's connect to the iron a must have to be able to get up all the solder to take it off?
Old Jun 7, 2009 | 12:29 AM
O5_TRD_tC's Avatar
try a solder sucker
Old Jun 7, 2009 | 04:34 AM
engifineer's Avatar
You can get a heated solder sucker that works pretty well at Radio Crack for about 10 bucks or so.
Solder braid is a braid of copper that is used to wick the solder up. It actually works very well if you use it right. I keep some around to clean up the bits of solder that the sucker does not pull out. With the braid, you lay the braid on the solder joint and lay the iron on top of the braid. The solder, once heated enough, will wick through the braid towards the heat.
Old Jun 7, 2009 | 05:51 AM
skinnayyy's Avatar
Team Scionara
alright thanks! i guess i don't have a desoldering braid but a solder sucker instead haha do you think radio crack would have the braid too?
Old Jun 7, 2009 | 05:56 AM
Garage1217's Avatar
Skip the braid IMO... I see way to many people overheat the screen from keeping heat on the pins for way to long with way to big of an iron... Go with the solder sucker! And use an appropriate iron... No need for a 45w with a 1/2" tip
With a decent quality solder sucker / iron combo, it should be no biggie to remove a screen without any damage in around 2 minutes or so.
Old Jun 7, 2009 | 05:58 AM
kmx22's Avatar
nah, I think desoldering braids work best. you just need a sharp tip with a 30watt solder. just make sure you do little by little, and not the whole thing at once. it's tough to get the solder inside the holes, but i've managed to do it.
Old Jun 7, 2009 | 06:02 AM
skinnayyy's Avatar
Team Scionara
how much does the braid generally cost? i was hoping to save some money by doing this myself.. .but having to buy extra tools and stuff i don't think i'll be saving much in the end >.>
Old Jun 7, 2009 | 06:07 AM
Garage1217's Avatar
I have had packets of braid laying around for.... 8-9 years? If you really want to go that route... I can send you some. Just pay shipping.
I also offer the HVAC exchange program. I stock a large qty of hvac's right now. I can fully mod one, ship it Monday & you would have it Wednesday. Then send your stock unit back for credit. I offer the service as I have had way to many customers screw up the LCD & have to buy a junk yard unit. If you are handy & have some soldering experience, then you should be able to tackle it. If you have a doubt in your mind, then it would be a pleasure to knock it out for you.
https://www.scionlife.com/forums/vie...ght=garage1217
Old Jun 7, 2009 | 03:19 PM
skinnayyy's Avatar
Team Scionara
haha thanks. alll i have to do is the LCD because i've already done evertything else, so if anything i'd do the braid way with you. I'll let you know in a couple days. Thanks!
yhwhdesign
Jun 11, 2021 03:34 PM
StxArOne
Scion xA Aero & Exterior
Apr 3, 2018 02:22 PM
Jumphiggggg
Scion tC 1G ICE & Interior
Jul 15, 2015 02:29 AM
excessads
Jul 13, 2015 11:41 AM
