Window / Door question
Old Jan 20, 2005 | 03:16 AM
idriveatC's Avatar
Default Window / Door question
I have a question about the door. I was wondering if it was normal for the door to "harbor" water? Everytime i wash the car, after a day or 2 i roll down the windows it will still pick up water when i roll back up. Is that normal? I mean every car is like that but this is alot of water and its in tehre for days... Maybe because its winter right now? Anyone else have this problem? Thanks
Old Jan 20, 2005 | 03:52 AM
toyota_scion_tc's Avatar
yes. water gets past the window seals and just sits there.
Old Jan 20, 2005 | 05:27 AM
Jammet's Avatar
You know, I didn't think about it much but that happens to me too. can this problem become serious and should it be dealt with the dealer?
Old Jan 20, 2005 | 05:58 AM
sciontc_mich's Avatar
all cars have some water in the doors, it's why they have drain holes in the door.. i noticed that the car that held the most water was my old mustang.. the least? my old crx si.. tC is about in the middle.. drains pretty quickly.. i don't know what the dealer can really do if they spray the door and out comes the water immediately.. it's more of a product engineering (that's the way it's made) kind of thing.. it can only become a problem in the cold as we're finding out that the window glass freezes up.. that's why I've recommended in other posts to apply (with a towel, easier that way) silicone spray to the window glass edge so that it won't freeze up.. if you're worried about your speakers getting wet, they have a plastic shield around them protecting them from the moisture in the door..
Old Jan 20, 2005 | 10:16 PM
idriveatC's Avatar
Thanks, because it was like 14degrees yesterday and windchill 17 so it was like 5 below zero yesterday. The water was still in there after 5 days and when i open the window nothing worked, so i pressed it again and i heard ice cracking. =( maybe i can drill a hole somewhere to drain it?
Old Jan 21, 2005 | 02:28 AM
i would take it to a hand held sprayer-type car wash.. to free up the windows, then dry the window's edge.. apply some silicone spray along the edge.. and at the bottom of the window glass (by where the glass meeting the door).. this should help it in not freezing.. but if you were serious, don't drill into your door..
one other thought i have is that when you spray the door with the water, see if there is any water coming out of the bottom of the door.. if there is, then it's normal.. if the water goes in and nothing drips out, then there is definitely a problem that the dealer needs to take a look at..
try those things and let us know.. it's been about -4 to about 15 degrees here in michigan so i am right in the same situation as you are.. and the water is draining out of my doors.. so let us know what happens when you try these things..
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
idriveanxa
Mar 8, 2015 12:03 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
toyotaisme
Jan 10, 2015 10:24 PM
